[Mapbender-users] treeConfGDE, ficheckbox, metadata...
Nicolas BACQ
nbacq at seine-aval.fr
Tue Jul 25 08:19:07 EDT 2006
Hi Astrid,
I worked last week on the elements vars ficheckbox and metadatalink to be
added to the mod_treefolderClient.php. What I have done :
> Starting from http\html\mod_tree_folder.php
> I replace "function init_array" by php code took from
http\html\mod_treefolderClient.php so that the module handle queries on
table gui_treegde
>I replace function Note by the one from http\html\mod_treefolderClient.php
> I add a function to get vars selectable ; visible ;queryable
;querylayer ;url; for each layer of treegde : it's called
"get_layer_attributefornote" that I call for each note if wms and shortname
layer are defined
> I specify a default url for metadas if it's not specify in database.
You have to put the files in html folder. And ckeck your database parameters
for element treegdeconf vars.
It works OK for on my mapbender application, but I found a first bug : if
you put a layer twice in your tree_treegde the code handle vars ficheckbox
and metadatalink only for the first one...
I think thats all.
If you want to have a look to the code...
Greetings from Rouen
Nicolas
-----Message d'origine-----
De : Astrid Emde [mailto:astrid.emde at ccgis.de]
Envoyé : mardi 11 juillet 2006 09:01
À : users at mapbender.osgeo.org
Objet : Re: [Mapbender-users] treeConfGDE, ficheckbox, metadata...
Nicolas BACQ schrieb:
> Hi list,
> Is there someone who did some work on treeConfGDE to support ficheckbox
and
> metadatalink, before I tried by my self ?
> Thanks for any help...
Hi Nicolas,
the elements vars ficheckbox and metadatalink are only implemented in
the element treeGDE.
The elements have to be added to the mod_treefolderClient.php. But this
isn't done yet.
When you try to implement it, it would be nice, if you could send the
code afterwards to the list, so that we can check in the code.
Greetings from Bonn
Astrid Emde
Astrid Emde
CCGIS GbR
Siemensstraße 8
53121 Bonn
Germany
www.ccgis.de
Tel.: ++49 (0) 228 90826 19
Fax.: ++49 (0) 228 90826 11
Zentrale: ++49 (0) 228 90826 0
To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
For additional commands, e-mail: users-help at mapbender.osgeo.org
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060725/5d5f44b8/mod_sync_treefolder_test.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060725/5d5f44b8/mod_treefolder_test.obj
More information about the Mapbender_users
