[Mapbender-users] newbie, unable to add wms
Vera Schulze
v.schulze at ccgis.de
Thu Jun 1 03:40:42 EDT 2006
Hi Rich,
I just tested this WMS. It works fine when you turn off the sublayers in
the GUI WMS settings.
So before adding the WMS to a gui, load the Capabilites Document, turn
off the sublayers and you can see the map and add it to other guis of
this owner.
See Arnulfs posting about Mapbender supporting nested layers for more
information on this topic.
Hope that helps,
Vera
Richard Greenwood schrieb:
> I am unable to add a WMS service (http://www2.tetonwyo.org/wms) to
> mapbender. I get "Error: no valid capabilities document..."
> The server is running Mapserver. A GetCapabilites request returns the
> results pasted below. I am able to add this service to Mapbuilder,
> MapInfo and ArcGIS, so I suspect I am doing something wrong, but I do
> not know how, or where, to begin debugging the error.
> Thanks for any suggestions.
> Rich
> ==== GetCapabilities return =============
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE WMT_MS_Capabilities SYSTEM
> "http://schemas.opengeospatial.net/wms/1.1.1/capabilities_1_1_1.dtd"
> <!ELEMENT VendorSpecificCapabilities EMPTY>
> ]> <!-- end of DOCTYPE declaration -->
> <WMT_MS_Capabilities version="1.1.1">
> <!-- MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG -->
> <Service>
> <Name>OGC:WMS</Name>
> <Title>Teton County, Wyoming WMS Server</Title>
> <Abstract>This experimental server provides access to GIS data
> produced by Teton County, Wyoming, USA</Abstract>
> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:href="http://www2.tetonwyo.org/wms?"/>
> </Service>
> <Capability>
> <Request>
> <GetCapabilities>
> <Format>application/vnd.ogc.wms_xml</Format>
> <DCPType>
> <HTTP>
> <Get><OnlineResource
> xlink:href="http://www2.tetonwyo.org/wms?"/></Get>
> <Post><OnlineResource
> xlink:href="http://www2.tetonwyo.org/wms?"/></Post>
> </HTTP>
> </DCPType>
> </GetCapabilities>
> <GetMap>
> <Format>image/gif</Format>
> <Format>image/png</Format>
> <Format>image/png; mode=24bit</Format>
> <Format>image/jpeg</Format>
> <Format>image/wbmp</Format>
> <Format>image/tiff</Format>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetMap>
> <GetFeatureInfo>
> <Format>text/plain</Format>
> <Format>application/vnd.ogc.gml</Format>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetFeatureInfo>
> <DescribeLayer>
> <Format>text/xml</Format>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </DescribeLayer>
> <GetLegendGraphic>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetLegendGraphic>
> </Request>
> <Exception>
> <Format>application/vnd.ogc.se_xml</Format>
> <Format>application/vnd.ogc.se_inimage</Format>
> <Format>application/vnd.ogc.se_blank</Format>
> </Exception>
> <VendorSpecificCapabilities />
> <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
> RemoteWFS="0"/>
> <Layer>
> <Name>wms</Name>
> <SRS>EPSG:4269</SRS>
> <SRS>EPSG:4326</SRS>
> <SRS>EPSG:26912</SRS>
> <SRS>EPSG:26712</SRS>
> <SRS>EPSG:102758</SRS>
> <SRS>EPSG:32158</SRS>
> <LatLonBoundingBox minx="-111" miny="43" maxx="-110" maxy="45" />
> <BoundingBox SRS="EPSG:4269"
> <ScaleHint min="0.349232" max="773.299" />
> <Layer>
> <Name>TC_Aerial</Name>
> <Title>2003 Aerial Photography</Title>
> <Abstract>TC_Aerial</Abstract>
> <Layer queryable="0" opaque="0" cascaded="0">
> <!-- WARNING: The layer name '03_fill' might contain spaces or invalid
> characters or may start with a number. This could lead to potential
> problems. -->
> <Name>03_fill</Name>
> <Title>Private Lands, 3 foot</Title>
> <ScaleHint min="1.29316" max="249.451" />
> </Layer>
> <!-- WARNING: The layer name '01' might contain spaces or invalid
> problems. -->
> <Name>01</Name>
> <Title>Private Lands, 1 foot ortho-imagery</Title>
> <ScaleHint min="0" max="1.29316" />
> </Layer>
> </Layer>
> <Layer>
> <Name>Contours</Name>
> <Title>Contours</Title>
> <Abstract>Contours</Abstract>
> <Name>contour</Name>
> <Title>5' elevation contours</Title>
> <LatLonBoundingBox minx="-111.053" miny="43.2259"
> maxx="-110.303" maxy="43.8837" />
> <BoundingBox SRS="EPSG:102758"
> minx="2.3691e+006" miny="1.3228e+006"
> maxx="2.56623e+006" maxy="1.56118e+006" />
> <Style>
> <Name>default</Name>
> <Title>default</Title>
> <LegendURL width="20" height="10">
> <OnlineResource
> xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
> xlink:href="http://www2.tetonwyo.org/wms?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=contour&format=image/png"/>
> </LegendURL>
> </Style>
> </Layer>
> </Layer>
> <Layer>
> <Name>Ownership</Name>
> <Title>Ownership</Title>
> <Abstract>Ownership</Abstract>
> <Name>State_Fed_thematic</Name>
> <Title>Public Land</Title>
> <LatLonBoundingBox minx="-111.067" miny="43.2323"
> maxx="-110.051" maxy="44.6704" />
> minx="2.36884e+006" miny="1.32514e+006"
> maxx="2.6332e+006" maxy="1.84789e+006" />
> <Style>
> <OnlineResource
> xlink:href="http://www2.tetonwyo.org/wms?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=State_Fed_thematic&format=image/png"/>
> </LegendURL>
> </Style>
> </Layer>
> <Name>State_Fed_Label</Name>
> <Title>Public Land Labels</Title>
> </Layer>
> <Layer queryable="1" opaque="0" cascaded="0">
> <Name>join_region</Name>
> <Title>Parcels</Title>
> minx="2.3688e+006" miny="1.32514e+006"
> <Style>
> <OnlineResource
> xlink:href="http://www2.tetonwyo.org/wms?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=join_region&format=image/png"/>
> </LegendURL>
> </Style>
> </Layer>
> </Layer>
> <Layer>
> <Name>Roads</Name>
> <Title>Roads</Title>
> <Abstract>Roads</Abstract>
> <Name>Road_CL</Name>
> <Title>Centerlines</Title>
> <LatLonBoundingBox minx="-111.488" miny="43.2041"
> maxx="-109.997" maxy="45.0266" />
> minx="2.26142e+006" miny="1.31636e+006"
> maxx="2.6469e+006" maxy="1.97776e+006" />
> <Style>
> <OnlineResource
> xlink:href="http://www2.tetonwyo.org/wms?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Road_CL&format=image/png"/>
> </LegendURL>
> </Style>
> </Layer>
> <Name>Road_Text</Name>
> <Title>Names</Title>
> </Layer>
> </Layer>
> </Layer>
> </Capability>
> </WMT_MS_Capabilities>
Mit freundlichen Grüßen
Vera Schulze
Vera Schulze
CCGIS GbR
Siemensstraße 8
53121 Bonn
Germany
www.ccgis.de
Tel.: ++49 (0) 228 90826 28
Fax.: ++49 (0) 228 90826 11
Zentrale: ++49 (0) 228 90826 0
More information about the Mapbender_users
