Antw: [Mapbender-users] Mapbender automatic authentication
Arnulf Christl (OSGeo)
arnulf.christl at wheregroup.com
Tue Apr 17 11:37:30 EDT 2007
On Tue, April 17, 2007 11:11, Simos Dimitrios wrote:
> That's what I meant, my error... it still doesn't work...
you need to create a user named "guest" (or whatever name you want to use)
with a password in Mapbender *and* give that user permission to open the
corresponding gui. Check this example:
http://wms1.ccgis.de/mapbender2/frames/login.php?name=mapbender&password=mapbender&mb_user_myGui=ccgis_de
So there must be a user named "mapbender" with the password "mapbender"
(watch out, it is not encrypted, do not use a valuable password!) and that
user needs to have permission to use the GUI named "ccgis_de".
If you use an arbitrary username (for example "foo") it will not work
because the instance of http://wms1.ccgis.de/mapbender2/ does not know the
user "foo". Therfore you end up on the login page:
http://wms1.ccgis.de/mapbender2/frames/login.php?name=foo&password=something&mb_user_myGui=ccgis_de
You can also log in as user "ccgis" and password "ccgis" and will see all
GUI that are open to this user (many are defunct, this is a nold test user
account).
Best regards,
Arnulf.
Arnulf Benno Christl
http://www.osgeo.org
(OSGeo Board Member)
+50.7342N +7.0707E
> -----Áñ÷éêü ìÞíõìá-----
> Áðü: mapbender_users-bounces at lists.osgeo.org åê ìÝñïõò Ronald Woita
> ÁðïóôïëÞ: Ôñé 17/04/2007 11:27
> Ðñïò: mapbender_users at lists.osgeo.org
> ÈÝìá: Antw: [Mapbender-users] Mapbender automatic authentication
> Hi,
> the correct request :
> ..mapbender/frames/login.php?name=guest&password=guest&mb_user_myGui=gui2
> Ronald
> Ronald Woita
> http://geoportal.rostock.de
> Hansestadt Rostock
> Kataster-, Vermessungs- und Liegenschaftsamt
> Holbeinplatz 14, 18069 Rostock
> email: ronald.woita at rostock.de
> phone: +49 (0)381 - 381 6256
>>>> simos at geo.aegean.gr 17.04.2007 10:15 >>>
> Hello list
> I am trying to create a link to a mapbender gui from a CMS tool, like
> Joomla.
> The URL is
> http://my_ip_address/mapbender/frames/login.php?&name=guest&password=guest&gui_id=gui2
> This does not work, as I want to have the user automatically authenticated
> (as a guest,
> for example), which, if I'm not mistaken, passes through a OWS proxy in
> order to get
> a php session id.
> How is this accomplished?
> Thanx
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
