[Mapbender-users] Digitizing module works in Firefox but not IE
knex0001 at umn.edu
knex0001 at umn.edu
Thu Aug 23 15:12:16 EDT 2007
Greetings
I have a problem that is stumping me and hope someone else has an idea. All
digitizing functions of our Mapbender install are working great with
Firefox, but not so well with IE6. Specifically the editing/updating
functionality.
I've got the problem narrowed down to fact that when in IE, d.get(i) does
not work. To test, I added an alert to updateListOfGeometries like this:
listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"'
title='"+buttonDig_remove_title[selectedLanguage]+"'onclick='alert(d.get("+i+"));parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>\n";
In Firefox, the alert box shows the geometry of the object, IE shows no
geometry.
I have made modifications to mod_digitize_tab.php as we do not have access
to a WFS-T server and are writing updates via SQL. However, I've gone back
to the original mod_digitize_tab, with only one modification (make
isTransactional true for WFS so objects will show in the geometry list).
The results are the same, no value for d.get(i) when using IE, but Firefox
works properly.
Here's a link to the application:
http://hegis.geog.umn.edu/mapbender_2.4.2_rc1/http/frames/login.php?&mb_user_myGui=MIIM%20Green&name=guest&password=hegis
Ideas would be greatly appreciated.
Thanks
Len
More information about the Mapbender_users
