[Mapbender-users] User resolution?
Uli Rothstein
uli.rothstein at ccgis.de
Mon Jan 8 04:11:46 EST 2007
2StepForward schrieb:
> Hello all,
> i have a problem with the user defined resolution. First, i try it about
> many ways to understand why the different resolutions, whitch i taste, has
> no effect. If I understand the right funtionality of this parameter, then it
> has only an effect to the Scale of the map and there ScalHints.
> I have taste many different user defined resolutions like 96, 300, 400 dpi.
> But the Scale, whitch was shown at first time if the map was drawn, don't
> change.
> Also the scalebar takes every time the same factor between real and
> projection.
> Why it doesn't work and what another effect has the user defined resolution?
> Thank,
> Klaus
Hello,
the user-defined resolution is only a column in the database for future
development. As far as I know there is no module implemented yet which considers
this parameter.
Best regards
Uli
Ulrich Rothstein
CCGIS GbR
Siemensstraße 8
53121 Bonn
GERMANY
www.ccgis.de
www.mapbender.org
Zentrale: ++49 (0) 228 90826 0
Durchwahl: ++49 (0) 228 90826 17
Fax: ++49 (0) 228 90826 11
More information about the Mapbender_users
