Antw: Re: [Mapbender-users] MB 2.4.2 RC - gazetteerWFS
knex0001 at umn.edu
knex0001 at umn.edu
Fri Jul 20 10:51:10 EDT 2007
Greetings
I was seeing the same behavior as stated below, all is now working
correctly with the updated files.
Thanks
Len
On Jul 20 2007, Christoph Baudson (WhereGroup) wrote:
>Hallo,
>das Problem ist inzwischen behoben worden.
>the problem has been solved.
>http://trac.osgeo.org/mapbender/ticket/72
>Christoph Ratke schrieb:
>> Helas all,
>> I am using the gazetteer as well and it is working fine - with Firefox.
>> Using IE I also have an empty iframe. The IE Error console tells me that
>> a "unbekannter Laufzeitfehler" (unknown runtime error?) in module
>> mod_wfs_gazetteer_client occurrs. In FF the javascript console is empty.
>> Does anybody have an idea?
>> @ Ronald: which browser(s) are you using?
>> Christoph Ratke
>> Am Freitag, den 20.07.2007, 10:34 +0200 schrieb Ronald Woita:
>>> Hi,
>>> The wfs_conf id is correctly inserted in the element_var
>>> 'wfsConfIdString' and there is'nt an error message in mapbender_log
>>> anymore, but the iframe is still blank. Looking at the following source
>>> text from my GUI I wonder about the line
>>> -->var targetString = 'mapframe1,overview';var wfsConfIdString =
>>> '';<-- Why is'nt there a value for wfsConfIdString although the same
>>> string in comment is correct ?
>>> greetings
>>> Ronald
>>> <script type="text/javascript">
>>> var wfsConfIdString = '11';
>>> </script>
>>> <style id="wfsConfStyle" type="text/css"></style>
>>> var targetString = 'mapframe1,overview';var wfsConfIdString = '';
>>> var targetArray = targetString.split(",");
>>> var global_wfsConfObj;
>>> var global_selectedWfsConfId;
>>> var point_px = 10;
>>> var resultGeom = null;
>>> var cw_fillcolor = "#cc33cc";
>>> Ronald Woita
>>> http://geoportal.rostock.de
>>> Hansestadt Rostock
>>> Kataster-, Vermessungs- und Liegenschaftsamt
>>> Holbeinplatz 14, 18069 Rostock
>>> email: ronald.woita at rostock.de
>>> phone: +49 (0)381 - 381 6256
>>>>>> verena.diewald at wheregroup.com 19.07.2007 08:53 >>>
>>> Ronald Woita schrieb:
>>>> Hi all,
>>>> in previous version 2.4.1 I used the module
>>>> '../php/mod_wfs_gazetteer.php'. In version 2.4.2 this was replaced by
>>>> '../javascripts/mod_wfs_gazetteer_client.php'. I tried to configure it
>>>> with the same WFS settings, but I get an empty iframe for the
>>>> gazetteerWFS and this error message in log :
>>>> 2007.07.19, 07:59:44,Error while executing prepared statement in
>>>> /srv/www/htdocs/mapbender/geoport_242/http/php/mod_wfs_gazetteer.php:
>>>> Sql: SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND
>>>> featuretype_id = $2, Error: ERROR: invalid input syntax for integer:
>>>> Are there any additional modules to load in the gui (excepting ajax)?
>>>> greetings
>>>> Ronald
>>>> Ronald Woita
>>>> Hansestadt Rostock
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Hi Ronald,
>>> as Mapbender uses now ajax for wfs gazetteer, wfs_conf IDs are now
>>> inserted comma separated in Element Var named "wfsConfIdString", not
>>> longer in src url. This could be the problem why you get the empty
>>> iframe. To get more information you can also have a look to Mapbender
>>> Wiki: http://www.mapbender.org/index.php/WFS_gazetteer#Element_vars
>>> Best regards
>>> Verena
>Baudson Christoph
>http://www.wheregroup.com
More information about the Mapbender_users
