[Mapbender-users] Projection problem
Stephan Holl
stephan.holl at intevation.de
Mon Mar 12 05:42:03 EDT 2007
Hello Arnulf,
"Arnulf Christl (WhereGroup)" <arnulf.christl at wheregroup.com>,
[20070309 - 14:58:13]
> No, I think thats it. Its part of Mapbender for year alread and
> except for teh setup has never caused major problems. If it does not
> resolve dump it to the tracker?!
No, the problem was that the postgis-installation lacked geos and
proj-support initially. After fixing this it worked.
Thanks for your pointers.
Best and see you in Berlin at FOSSGIS 2007
Stephan
> >> > I assue the transformation is somewhat faulty and the resulting
> >> > BBOX-Parameters are wrong. The follwing request is generated when
> >> > selecting EPSG:31469 from the menu:
> >> > BBOX contains 0,NaN,0,NaN.
> >> > The following are taken from the metadata-document:
> >> > before transformation
> >> > http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_
> >> > user.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=Mapbender_User,Mapb
> >> > ender_Names&STYLES=,&SRS=EPSG:31467&BBOX=2931821.5625,5248260,4262868.4375,6
> >> > 100130&WIDTH=625&HEIGHT=400&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TR
> >> > UE&EXCEPTIONS=application/vnd.ogc.se_xml
> >> > After transformation:
> >> > ender_Names&STYLES=,&SRS=EPSG:31469&BBOX=0,NaN,0,NaN&WIDTH=625&HEIGHT=400&FO
> >> > RMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.
> >> > ogc.se_xml
> >> > Is this a known problem?
> >> > Best
> >> > Stephan
> >> > _______________________________________________
> >> > Mapbender_users mailing list
> >> > Mapbender_users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Stephan Holl <stephan.holl at intevation.de>,
> > http://intevation.de/~stephan Tel: +49 (0)541-33 50 8 32 |
> > Intevation GmbH | AG Osnabrück - HR B 18998 Geschäftsführer: Frank
> > Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
More information about the Mapbender_users
