[Mapbender-users] 'root' mit mysql
Veselina Dencheva veselinadencheva at gmail.com
Wed Mar 21 11:14:11 EDT 2007
 1. Der Befehl create user will irgendwie nicht funktionieren, kannn es
 sein dass es an der mysql version liegt, die ist ja mysql-4.1.14 und
 nicht 5.02 wo es create user gibt.
 Die Fehlermeldung ist:
 #1064 - You have an error in your SQL syntax; check the manual that
 corresponds to your MySQL server version for the right syntax to use
 near 'USER 'mapbender'@ 'localhost' IDENTIFIED BY '0815'' at line 1
 2. http://localhost/mapbender/tools/mapbender_setup.php zeigt folgendes:
_____________________________________________________________________
Setup-Checker
PHP Configurationcheck
php Version	       X      Version: 5.1.4
interface		  X	  Modul-PHP
path to php.ini		X       C:\ms4w\Apache\cgi-bin\php.ini
extension_dir	       X	/ms4w/Apache/php/ext/(check the path, is it correct?)
session.save_path   X       /ms4w/tmp (check out the authorisation of the dir)
memory Limit	      X      8M (running in memory-trouble with printing?
Perhaps raise your memory limit)
error-reporting		X	ok, error_reporting = E_ALL & ~E_NOTICE
session.save_handler	X	session.save_handler = files
file_Uploads		X	On
allow_url_fopen		X	On
PHP Extensioncheck
MySQL check		X	MySQL installed
PostgreSQL check	X	PostgreSQL installed
GD2 check		X	GD installed
Warning: pg_connect() [function.pg-connect]: Unable to connect to
PostgreSQL server: missing "=" after "with" in connection info string
in C:\ms4w\apps\mapbender\HTTP\TOOLS\mapbender_setup.php on line 128
Database check
Administration Database	X	MySQL
Connect to Database		not connected
PostGIS function check
Postgis support		 no PostGIS function available
mapbender.conf check
Administration Database	X	mysql
DB-Server		X	localhost (is this your DB-Server)
Mapbender-DB		X	mapbender (is this your Mapbender-DB)
DB-Owner		X	mapbender (is this your DB-Owner)
PREPAREDSTATEMENTS-
compatibility		X	set to 'true' and php 5.1.4 should work
CHARSET		X	UTF-8
TMPDIR		X	../tmp
MAXLOGIN	X	3
Login-Path	http://localhost/mapbender/frames/login.php
(if this link doesn't work, check out your 'URL to Login' in your mapbender.conf
Perhaps an alias in your httpd.conf will solve the prob')
 Beseonders der Teil in Database check (Connect to Database              not
 connected ) gefaellt mir nicht
Gruesse, Veselina
> 2007/3/21, Tilo Wütherich <tilo.wuetherich at la-bw.de>:
> > Hallo Veselina,
> > ich schätze, das ist der Fehler: Du mußt noch einen MySQL-Benutzer anlegen
> > und ihm Schreib-/Leserechte in der Datenbank mapbender geben. Per SQL also
> > ein
> > CREATE USER 'mapbender'@ 'localhost' IDENTIFIED BY '****';
> > etc.
> > oder per PHPMyAdmin. Der Benutzer kann z.B. mapbender heißen und das Paßwort
> > 0815 erhalten. In der mapbender.conf steht dann:
> >  if(SYS_DBTYPE=="mysql")
> >         define("DBSERVER", "localhost");
> >         define("PORT", "3306");
> >         define("DB", "mapbender");
> >         define("OWNER", "mapbender");
> >         define("PW", "0815");
> > Der Benutzer root/root ist der Mapbender-Benutzer, mit dem Du Dich über den
> > Browser anmeldest.
> > Ich hoffe, ich konnte helfen!
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Remote Sensing Applications Center (ReSAC)
> 61 Tzar Assen Str.
> 1463 Sofia, Bulgaria
> Tel: +359 2 9800731
> Tel: +359 2 9812231
> Fax: +359 2 9818216
> e-mail: resac at techno-link.com
> URL: www.resac-bg.org
61 Tzar Assen Str.
Tel: +359 2 9800731
Tel: +359 2 9812231
Fax: +359 2 9818216
More information about the Mapbender_users mailing list
