[Mapbender-users] Limited GetFeatureInfo-Output?
Tilo Wütherich tilo.wuetherich at la-bw.de
Thu Nov 22 08:59:06 EST 2007
Hi Michael,
> yes, there is the parameter mb_feature_count in map.js, which is set
> to100. I think you will have to edit it there (please correct me if
> there is configuration parameter somewhere). It is appended to each
> getfeatureinfo request when set to > 0 .
that was it! I suggest to make these params configurable in a central file.
Greetings,
Tilo
More information about the Mapbender_users mailing list
