AW: [Mapbender-users] Save WMC doesnt't work
Samson, Marko Marko.Samson at wald-und-holz.nrw.de
Tue Oct 23 07:33:09 EDT 2007
I just continued to search for a solution to solve the problem and installed a new clean 2.4.3 mapbender version on my local pc to isolate the problem.
With the new and clean installation, I can save and load the wmc. But there are two behaviours I'd like to understand.
1. after clicking the save_wmc button (standard gui1), I wanted to cancel with the "cancel" button. But the wmc is still saved with wmc_name(wmc_title) "null" and the alert windows confirms me this saved "null"-wmc. Rest of the mb_user_wmc is filled as it should and loading the "null"-wmc works fine (bug or wrong configuration?)
2. Is it a new feature, that loading a wmc adjusts the boundingbox of the overview? If it's a feature, where can I configure the overview to keep the old standard bbox from the startup?
Greetings,
Marko Samson
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Samson, Marko
Gesendet: Dienstag, 16. Oktober 2007 16:55
An: Mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] Save WMC doesnt't work
Hello List,
After an update from 2.4.0 step by step to 2.4.3 I just recognized, that the savewmc doesnt work anymore.
It seems, that my mb has a problem while collecting the data for the wmc. The saved wmc_text looks like this:
<ViewContext xmlns="http://www.opengis.net/context" version="1.0.0" id="1_1192544540" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:mapbender="http://www.mapbender.org" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:SchemaLocation="http://schemas.opengis.net/context/1.0.0/context.xsd">
<General>
<Window/>
<BoundingBox SRS="" minx="0" miny="0" maxx="0" maxy="0"/> <Name>Mapbender WMC</Name> <Title>test</Title> <KeywordList> <Keyword>Mapbender</Keyword> <Keyword>WMC</Keyword> </KeywordList> </General> <LayerList/> </ViewContext>
Additional there is a strange behaviour. When I press the "Abbrechen" Button at the SaveWMC window, there is still opening an alertmessage with "WMC document 'null' has been saved."
Loading the WMC causes an error(seems to be a problem of the missing data from the wmc xml) in line 26
25 if (old_mapObj[i].frameName != 'overview') {
26 window.opener.mb_registerMapObj(old_mapObj[i].frameName, old_mapObj[i].elementName, null, , );
27 window.opener.document.getElementById(old_mapObj[i].frameName).style.width = ;
28 window.opener.document.getElementById(old_mapObj[i].frameName).style.height = ;
29 }
Does anybody know, or has an idea, how I can solve or isolate the problem?
One additional little question:
Is it possible to adjust the opacity by the treegde2 function with IE6 or 7. If so, whats the trick for the IE?
Greetings,
Marko Samson
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
Mapbender_users mailing list
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
