[Mapbender-users] Zoom and Center Module
Len Kne
knex0001 at umn.edu
Tue Apr 15 16:42:41 EDT 2008
Tilo
Thanks for pointing me to the where to make the change to the "zoom factor",
this does exactly what I was looking for. I ended up making two copies of
the center module so I could get this behavior with zoom in and zoom out
tools.
I was going to setup the JavaScript variable in hopes of loading the
"center" module twice and changing the zoom factor, but ran into a larger
issue with the creating of the button. Maybe in the future.
Len
-----Original Message-----
[mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of Tilo Wutherich
Sent: Thursday, April 10, 2008 4:15 AM
To: Mapbender User List
Subject: RE: [Mapbender-users] Zoom and Center Module
I forgot:
> >My question is has anyone developed a module that combines center and
> >ZoomIn? I did not see it in the list of modules. If not, I'll give
> >it a try - I'm thinking it should be fairly straightforward.
to have a zoom, you must edit line 76 of mod_center1.php. You can even
define a javascript-var and make it configurable via the admin-gui. Probably
this would be an improvement of the module for the next Mapbender-releases?!
What do the devs think about it?
Cheers,
Tilo
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
