[Mapbender-users] legend printing
Michael Schulz
mschulz at webgis.de
Mon Aug 4 09:00:24 EDT 2008
Hi Ronald,
just tried it with pretty the same setup, and got no problems.
Are you sure, that you didn't incidentially resize the mapframe prior
to printing?
Just to be sure: it's not that e.g. the main map area is empty
(problems loading the wms) and you only see the overview map?
Cheers, Michael
2008/8/4 Ronald Woita <Ronald.Woita at rostock.de>:
> and right away the next problem :-(
> printing with enabled legend (and only if the wms-service delivers some
> pictograms) produces a two-sided pdf-document.
> So far so good. But the size of the printed mapframe is to small
> (perhaps a quarter from the expected size)
> and located at the lower left corner of the papersize.
> If someone can prove this, I will create a new ticket at the
> bugtracker.
> Mapbender 2.5 RC5
> UTF-8
> PostgreSQL 8.3.x
> i18 enabled ;-)
> greets
> Ronald
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users
