[Mapbender-users] German 'Umlauts' in PDF-Print
Michael Schulz mschulz at webgis.de
Wed Aug 6 07:21:53 EDT 2008
Hi Ronald,
I have filed a ticket concerning a similar problem, that one will face
when using i18n with printPDF:
http://trac.osgeo.org/mapbender/ticket/265
I am not even sure if this is a problem related only to the encoding,
but maybe also to the font used in pdf printing. If it were "only"
encoding problems, then we didn't have to use this special character
array you'll find in mod_printPDF_pdf.php. But I agree, that pdf only
works with iso-8859-1 characters.
Cheers, Michael
2008/8/6 Ronald Woita <Ronald.Woita at rostock.de>:
> Hi Marc,
> thanks for your reply Marc-
> 'file printPDF.conf' only delivers this result--> PHP text File,
> but 'less printPDF.conf' displays correct characters on a bash.
> But if I convert the string to ISO-8859-1 (see below) everything is fine ?!
> # labeling
> if(CHARSET=="UTF-8"){
>        $new_comment1 = utf8_decode($_REQUEST["comment1"]);
>        $new_comment2 = utf8_decode($_REQUEST["comment2"]);
> else{
>        $new_comment1 = $_REQUEST["comment1"];
>        $new_comment2 = $_REQUEST["comment2"];
> $text1 = utf8_decode("GeoPort.HRO");
> $text2 = utf8_decode"das GeodatenPortal für die";
> $text3 = utf8_decode"Hansestadt Rostock und Umgebung";
> $text4 = utf8_decode"";
> $text5 = utf8_decode("Maßstab ca. 1:"). " ".$_REQUEST["map_scale"];
> If I understand this in the correct manner, then the pdf class seems to use ISO encoding ?
> greets
> Ronald
>>>> jansen.marc at gmx.de 06.08.2008 10:01 >>>
> Hi Ronald,
> when you edited the printPDF.conf, did you save the file UTF8-encoded?
> What is the output of:
> file printPDF.conf
> (on a linux-prompt, assuming your installation is running on a linux system)
> Have you tried e.g. iconv? (make sure you've got a backup)
> --Marc
> Ronald Woita schrieb:
>> Hi list,
>> I'm still working on the pdf printing process...
>> There is text with 'umlauts'  in my printPDF.conf, but these 'umlauts'
>> does'nt display correct in the pdf-document.
>> I just tried to replace the 'umlauts' with html notation, but this
>> does'nt work too.
>> The whole system enviroment is configured as UTF-8, eg. OS, database,
>> Apache... so I don't know, what's the cause of it.
>> Does anybody get an idea, how to solve this issue ?
>> Mapbender 2.5 rc5
>> PostgreSql 8.3
>> UTF-8
>> greets
>> Ronald
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
