[Mapbender-users] problems when installing rc6
Christoph Baudson
christoph.baudson at wheregroup.com
Wed Aug 20 03:57:38 EDT 2008
Thanks for letting us know.
The changes have somehow not made it into the schema dump. Please run
the update SQL file
update_2.5rc6_pgsql.sql
in the update folder (even on a fresh installation).
Manns, Marc schrieb:
> Hi List,
> i tried to install the new Version number (2.5rc6).
> If you make a fully new installation you will run through an error
> while filling the database.
> ERROR: column "wms_mb_getcapabilities_doc" of relation "wms" does not
> exist
> The reason for this error is the pgsql_schema.sql
> the statement of the wms-table creating is not correct.
> (Here a short snapout from line 630-663).
> CREATE TABLE wms (
> wms_id serial NOT NULL,
> wms_version character varying(50) DEFAULT ''::character varying
> NOT NULL,
> wms_title character varying(255) DEFAULT ''::character varying NOT
> NULL,
> wms_abstract text,
> wms_getcapabilities character varying(255) DEFAULT ''::character
> varying NOT NULL,
> wms_getmap character varying(255) DEFAULT ''::character varying
> NOT NULL,
> wms_getfeatureinfo character varying(255) DEFAULT ''::character
> varying NOT NULL,
> wms_getlegendurl character varying(255),
> wms_filter character varying(255),
> wms_getcapabilities_doc text,
> wms_owsproxy character varying(50),
> wms_upload_url character varying(255),
> fees character varying(255),
> accessconstraints text,
> contactperson character varying(255),
> contactposition character varying(255),
> contactorganization character varying(255),
> address character varying(255),
> city character varying(255),
> stateorprovince character varying(255),
> postcode character varying(255),
> country character varying(255),
> contactvoicetelephone character varying(255),
> contactfacsimiletelephone character varying(255),
> contactelectronicmailaddress character varying(255),
> >>>> wms_mb_getcapabilies_doc text,<<<
> wms_owner integer,
> wms_timestamp integer,
> wms_supportsld boolean,
> wms_userlayer boolean,
> wms_userstyle boolean,
> wms_remotewfs boolean
> line 656 must rewrite from
> wms_mb_getcapabilies_doc >> wms_mb_getcapabilities_doc
> after this changing everything runs fine.
> Greetings
> Marc
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
