[Mapbender-users] problem with wms after importing gui on server
Ulrich Rothstein
uli.rothstein at wheregroup.com
Tue Jan 1 10:15:30 EST 2008
Hey Karsten,
I just get an error-message if I try to load the capabilities document:
msLoadMap(): General error message. Undefined overlay symbol "POINT" in
class 0, style 1 of layer Active Attorneys. msAddImageSymbol(): Unable to
access file. Error opening image file
/var/www/mapdata/projects/alliance/POINT.
regards
Uli
On Sat, December 29, 2007 9:04 am, karsten vennemann wrote:
> Hi list,
> I'm working with mapbender 2.4.3 and created a gui including one wms
> (http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/project
> s/ alliance/ok_server.map
> <http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/projec
> ts/ alliance/ok_server.map&> &) on my local windows machine. There all is
> working fine. I then exported the gui as sql and imported into the
> mapbender database (postgis) on my linux server. The gui shows up on the
> admin pages after I ran Insert into gui_mb_user Values ('ocla1',1,'owner');
> However, the wms does not show up when I load the gui, also I can't find
> my wms in the table "wms" nor does it show up when I try to edit the wms
> under Configue WMS access> WMS GUI settings in the WMS_TiTle list box.
> I don't know whether a wms belonging to a gui usually is exported with the
> gui - or whether I have to recreate that resource on the server again?
> Thus, I tried to recreate the wms with "load capabilities", however
> trying to load
> s/a lliance/ok_server.map
> ts/
> alliance/ok_server.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0>
> gives me a violation of a constraint :-(:
> Warning: pg_exec() [function.pg-exec
> <http://alliance.terragis.net/php/function.pg-exec> ]: Query failed:
> ERROR:
> duplicate key violates unique constraint "pk_gui_layer" in
> /var/www/sites/mapbender/http/php/database-pgsql.php on line 133
> sql error: ERROR: duplicate key violates unique constraint "pk_gui_layer"
> ROLLBACK performed....
> Now I'm stuck and don't know how to port gui and wms to the server. Any
> ideas what went wrong, or how I can fix this?
> Karsten
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
