[Mapbender-users] Load WMC
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Thu Jan 17 09:10:20 EST 2008
Thanks for your mail, David. You are right, there seems to be a problem.
I will create a ticket and take a look at it.
Thanks
Christoph
David Arndt schrieb:
> Hello,
> I have a problem with mapbender 2.4.4, when I'm loading a saved wmc
> the overview and the Layertree is not loading correct.
> For a few weeks I reported the problem with the function
> mb_execloadWmcSubFunctions() (which is not found). This is the only
> error message I get.
> I'm using a unmodified mapbender.
> Regards, David Arndt.
> geoinformation+planung
> reichert+partner ingenieure
> gölzstr. 22 72072 tübingen
> fon: +49 (0)7071-407360
> fax: +49 (0)7071-407361
> arndt at geoinformation-planung.de
> geoinformation+planung - reichert+partner |
> http://www.geoinformation-planung.de
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
