[Mapbender-users] Neue Version - andere BBox
Sascha Bahl sbahl.ml at gismobil.de
Mon Jan 21 10:02:07 EST 2008
Hello again!
There is a bug in the module mod_dynamicOverview.php. I have copied the
gui2, remove all wms and add my own. For Example a map for RLP:
http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv4102.fcgi?map=/data/umn/navigation_atkis_ldi.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
The requested parameters for bbox are wrong, but only in the version
2.4.4. The difference between the version 2.4 and 2.4.4. is apparently
the module dynamicOverview, which is enable by default. If this module
is disabled, than the requested bbox parameter are right.
Cu
Sascha Bahl
<http://dict.leo.org/ende?lp=ende&p=eL4jU.&search=apparently>
More information about the Mapbender_users mailing list
