[Mapbender-users] MB 2.5rc2: Problems wirh switchLocale_noreload
Michael Schulz mschulz at webgis.de
Tue Jun 3 07:24:20 EDT 2008
Hello Herr Schönhammer,
did you solve this issue in the meantime? If not, please check your
webservers error log file for the following entry (this is from an
apache log):
[Tue Jun 03 14:14:04 2008] [error] [client 87.193.233.2] malformed
header from script. Bad header=Content-type='text/plain';Char: php,
referer:
I had the same behaviour you described in your mail and found the
solution due to this entry in the error log. You can fix this by
changing the script php/mod_setLocale.php, line 27 from
header("Content-type='text/plain';Charset='utf-8'");
to
header('Content-type: text/plain; charset="utf-8"');
I'll send a copy of this mail to the dev-list so that this issue is
reviewed and if still necessary fixed.
Greetings, Michael Schulz
2008/4/28 "Schönhammer, Herbert" <Schoenhammer.Herbert at regensburg.de>:
> Hi list,
> with MB 2.5rc2 I want to use module switchLocale_noreload.
> I have defined in mapbender.conf:
> # Internationalization
> define("USE_I18N", true);  // requires gettext for PHP.
>                                                         // If "false",
> LANGUAGE is set to english
> define("LANGUAGE", "de");   // only available if USE_I18N is "true".
>                                                         // "en", "de", "bg",
> "gr", "nl", "it", es"
> require_once(dirname(__FILE__) . "/../lib/i18n.php");
> I have embedded module switchLocal__noreload in my gui with variable:
> languages set to "de,en,bg,gr,nl,it,es"
> In my gui the drop-down box for selecting the languages is displayed.
> I am able to select different languages.
> But: After selecting a different langauge, nothing happens. The language is
> NOT changed.
> After reloading the gui in my browser, the language is changed.
> Is it possible to change the language at once, after the user has changed
> the language via the drop down box ?
> Greetings
> Schoenhammer Herbert
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
