AW: [Mapbender-users] Problems with EPSG
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Wed Jun 18 04:38:57 EDT 2008
Buchholz, Robert schrieb:
> Hi Astrid,
> gratulations for perfect guidiance to Sandra...
> One question considering MB table layer_epsg:
> - what is this table for?
> I do find 100% identical rows! Some others seems to be wrong!
> Can/schould I delete them?
> Saludos,
> Robert
Hello Robert,
layer_epsg saves the BoundingBox from the Capabilities-Document for
every layer (if the information is provided). With this information
Mapbender can choose the start extent and Mapbender can use this
information to zoom to the Extent of a layer (see treeGDE).
have a look at the following Wiki Pages:
http://www.mapbender.org/Database_Changes_2.4.1
It discribes how to delete double entries from table layer_epsg.
To clean your database see also (Topic 7):
http://www.mapbender.org/Update_mapbender_2.2.3_to_2.4.3
schau Dir am Besten mal die folgende WIKI-Seite dazu an:
Hier wird beschrieben, wie doppelte Einträge aus der Tabelle layer_epsg
entfernt werden können.
ebenso Punkt 7 auf der Seite:
Schönen Gruß Astrid
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde (WhereGroup)
> Gesendet: Dienstag, 17. Juni 2008 14:16
> An: mapbender_users at lists.osgeo.org
> Betreff: RE: [Mapbender-users] Problems with EPSG
> Hi Sandra,
> just some more information to get your WMS runnig:
> Go to admin2_en -  WMS GUI settings. Klick on your WMS and have a look at the layers. The Layer with Nr. 0 i your root layer. Find out the layer_id.
> Run the following SQL (replace the <layer_id>):
> INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) VALUES (<layer_id>, 'EPSG:32761', -2644018.138249832,1809033.7193695423,-2609670.4495129166,1855366.7973831547);
> Go again to admin2_en -  WMS GUI settings and coose the WMS. You should now have the possibility to choose the new EPSG.
> Best regards astrid
> On Tue, June 17, 2008 12:57 pm, Sandra Mink wrote:
>> Hi, again!
>> Many thanks Len and Astrid for your quick responses!
>> Len, I have edited the changeEPSG and added a row with the 32761
>> EPSG.Now I can select 32761 in the GUI but it doesn't work because I
>> get the following error message:
>> "Failed to load WMS .. from server ... Do you want to try it in a new
>> window?"
>> To avoid more problems right now I have only one WMS loaded, mine from
>> geoserver. It's true that in the WMS to GUI settings menu it is set to
>> 4326, but I don't know how to change it...
>> Astrid, I have looked at the layer_epsg and it seems that there is a
>> layer only with EPSG 4326. I think it is not really a layer in
>> geoserver, but the Title I gave to the WMS configuration. That's what I see:
>> id: 0 parent: name: Elefante WMS title: Elefante WMS queryable: 0
>> minScale: 0 maxScale: 0dataurl: metadataurl:
>> EPSG:4326
>> -178.20351006019976
>> -50.07764976069634
>> -177.64443958125736
>> -49.81625887166632
>> layerstyle:
>> name
>> title
>> legendurl
>> legendurlformat
>> id: 1 parent: 0 name: ele:Linea de costa title: coast_Type queryable:
>> 1
>> EPSG:4326
>> -178.20351006019976
>> -50.07764976069634
>> -177.64443958125736
>> -49.81625887166632
>> EPSG:32761
>> -2644018.138249832
>> 1809033.7193695423
>> -2609670.4495129166
>> 1855366.7973831547
>> I have added a row to the table with the BoundingBox limits as you
>> told me. But now my question is (perhaps a very simple one) how do I
>> update this values in mapbender? I have tried it with the update WMS
>> but I don't see any changes???
>> I would be very, very thankful if you help me to solve this!
>> Vielen, vielen Dank!!
>> Sandra
>>> Date: Tue, 17 Jun 2008 11:23:26 +0200> Subject: RE: [Mapbender-users]
>>> Problems with EPSG> From: astrid.emde at wheregroup.com> To:
>>> mapbender_users at lists.osgeo.org> > Hello Sandra,> > the problem is
>>> that GeoServer does not serve the BoundingBox-Tag in the> XML.
>>> GeoServer only offers the LatLonBoundingBox in 4326.> > Here is an
>>> examle with UMN MapServer:> -----------> <Layer queryable="0"
>>> opaque="0" noSubsets="0">> <Name>myRootLayer</Name>>
>>> <Title>myRootLayer</Title>> <SRS>epsg:31466</SRS>>
>>> <SRS>epsg:31467</SRS>> <SRS>epsg:4326</SRS>> <LatLonBoundingBox
>>> minx="6.93635" miny="50.8018" maxx="7.01256"> maxy="50.8501" />> <BoundingBox SRS="EPSG:31466" minx="2.566e+006"
>>> miny="5.62995e+006"> maxx="2.5713e+006" maxy="5.63525e+006" />> ....>
>>> ------> > Mapbender can only start with the EPSG-Code, where
>>> ------> > Mapbender
>>> has a> corresponding BBOX.> > If you want to add a BoundingBox and an
>>> EPSG to start your gui with this> EPSG, you have to add a new row in
>>> the Mapbender table layer_epsg.> > Find out the layer_id of you root
>>> layer and add a new row for the> EPSG-Code you are interested in.> >
>>> After that you should have the possiblity to choose this new EPSG
>>> from the> dropdown list in the WMS GUI Settings.> > Greetings from
>>> Bonn> > astrid>
>>>> On Mon, June 16, 2008 6:17 pm, Len Kne wrote:> > Sandra> >> > I'm
>>>> not
>>> familiar with geoserver, but it sounds like geoserver is rendering> >
>>> the map properly and not the issue. Couple ideas in Mapbender. First,
>>> I>
>>>> would suggest turning off the change ESPG module while
>>>> troubleshooting
>>> -> > once it works, bring it back. Depending on which version of
>>> Mapbender you> > are using, you may have may have to add a line of
>>> code to changeESPG.php> > to> > include your projection. The scale
>>> bar also does not work properly in> > lat/lon (4326), but should be
>>> ok once you get to your projection.> >> > In the Admin module, look
>>> at "WMS GUI settings". The top WMS of an> > application/gui sets the
>>> default projection. I'm guessing your first WMS> > is> > set to 4326.
>>> You might have to move your WMS from geoserver to the top> >
>>> position, thus allowing you to select 32761 projection.> >> > Len> >>
>>>>>> _____> >> >
>>> From: mapbender_users-bounces at lists.osgeo.org> >
>>> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of Sandra
>>> Mink> > Sent: Monday, June 16, 2008 10:58 AM> > To:
>>> mapbender_users at lists.osgeo.org> > Subject: [Mapbender-users]
>>> Problems with EPSG> >> >> > Hi list,> >> > I'm using geoserver 1.6.4
>>> and mapbender with a Postgis database to put my> > maps on the web as
>>> a part of a project. I'm really a newbie to all this.> > After having
>>> a lot of trouble I finally made it and I got to see my> > layers,> >
>>> but ... they appear to be a mirror image and distorted. I realized
>>> they> > are> > projected in EPSG 4326, although I defined EPSG 32761
>>> in geoserver,
>>> where> > everything worked well. Also the scale doesn't seem to
>>> where> > work.> >
>>> When I change EPSG in the Mapbender GUI it returns an error. And I
>>> don't> > know how to add other EPSG in the dropdown list in the WMS
>>> GUI
>>> Settings> > Menu. I've tried to make some edits but haven't had
>>> Settings> > luck!>
>>>>>> I need to use EPSG: 32761: Universal Polar Stereographic because
>>> I'm> > working> > on a area near Antarctica.> >> > I've seen on the
>>> posts that somebody else had similar problems. I would> > appreaciate
>>> every kind of help! Is there a way to solve this?> >> > Many thanks!>
>>>> Sandra> >> >> > _____> >> > Sigue de cerca las últimas tendencias y
>>>> Sandra> >> >> > lo
>>> que más rompe MSN Vídeo> >
>>> <http://video.msn.com/video.aspx?mkt=es-es>>
>>>>>> _______________________________________________> >
>>>>>> Mapbender_users
>>> mailing list> > Mapbender_users at lists.osgeo.org> >
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users> >> > > Mit
>>> freundlichen Grüßen> > Astrid Emde> >
>>> ----------------------------------> > Astrid Emde> WhereGroup GmbH &
>>> Co.KG> Siemensstraße 8> D-53121 Bonn> > Fon: +49(0)228 90 90 38 - 19>
>>> Fax: +49(0)228 90 90 38 - 11> > astrid.emde at wheregroup.com>
>>> www.wheregroup.com> > ----------------------------------> >
>>> _______________________________________________> Mapbender_users
>>> mailing
>>> list> Mapbender_users at lists.osgeo.org>
>> _________________________________________________________________
>> MSN Video.
>> http://video.msn.com/?mkt=es-es
> Mit freundlichen Grüßen
> Astrid Emde
>   Astrid Emde
>   WhereGroup GmbH & Co.KG
>   Siemensstraße 8
>   D-53121 Bonn
>   www.wheregroup.com
> Mapbender_users mailing list
Astrid Emde
 Astrid Emde
 Siemensstraße 8
 53121 Bonn
 Germany
 www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
