[Mapbender-users] Antwort: Mapserver Imagecolor
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon May 5 05:28:47 EDT 2008
Hello,
when Mapbender performs the MapRequests The parameter TRANSPARENT=True
is uses by default. Here is an example for such a MapRequest
http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Strassen,Staedtepunkte,Staedtenamen,Bundeslaendernamen&STYLES=,,,,,,,,,&SRS=EPSG:31467&BBOX=2931821.5625,5248260,4262868.4375,6100130&WIDTH=625&HEIGHT=400&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
This is usefull when many WMS overlay eachother.
Although you defined blue as background color this is not displayed,
because the image is requested transparent. In the Request you see the
paramter BGCOLOR=0xffffff& to set the Backgroundcolor. This is set to
white by default by Mapbender. You could change all this in the code in
mapbender/php/map.js (line 664 function setMapRequest)
The better way would be to create a new layer in your mapfile which
represents the background. You could create a layer with an inline
feature (http://mapserver.gis.umn.edu/docs/reference/mapfile/feature)
that covers the whole extent of your WMS.
best regards astrid
aldiaz84 schrieb:
> Ok, but i'm talking about the background color of the mapframe
> Are a similar field for that atributte?
> Thanks a lot!
> d.stockhaus wrote:
>> Hi,
>> as far as I know, Mapbenmder don´t use the Backgroundclour defined in the
>> Mapfile. The Background is set to white by default. But You can edit it.
>> In Mapbender Administration Gui go to Edit Gui Elements, select your GUI
>> and there click on the element body (On the Name, not on the Radio
>> Button).
>> A new window with edit element vars will open. there you have a radio
>> button with css_class_bg. Choose this and in the field VALUE you can edit
>> the Colour of your background.
>> Mit freundlichem Gruß,
>> Detlef Stockhaus
>> Zentraler Service / IT
>> Anwendungsentwicklung
>> Telefon: 040 - 2576 1561
>> Fax: 040 - 2576 1500
>> Mobil: 0162 - 288 1561
>> STADTREINIGUNG HAMBURG
>> ENTSORGUNGSFACHBETRIEB, zertifiziert für das
>> Einsammeln, Befördern, Lagern, Behandeln von
>> Abfällen zur Verwertung und Beseitigung.
>> Anstalt des öffentlichen Rechts, Bullerdeich 19, 20537 Hamburg
>> Vorsitzende des Aufsichtsrats: Staatsrätin Dr. Herlind Gundelach
>> Geschäftsführer: Dr. Rüdiger Siechau, Werner Kehren
>> Tipps, Termine und Dienstleistungen
>> rund um die Abfallentsorgung in Hamburg finden Sie auch unter
>> http://www.stadtreinigung-hh.de
>> Informationen der Stadtreinigung Hamburg erhalten Sie stets
>> aktuell durch den E-Mail-Newsletter. Anmeldung über:
>> http://www.srhh.de/srhh/servlet/NewsletterLogonServlet.do
>> aldiaz84 <aldiaz84 at gmail.com>
>> Gesendet von: mapbender_users-bounces at lists.osgeo.org
>> 29.04.2008 18:48
>> Bitte antworten an
>> Mapbender User List <mapbender_users at lists.osgeo.org>
>> An
>> Mapbender_users at lists.osgeo.org
>> Kopie
>> Thema
>> [Mapbender-users] Mapserver Imagecolor
>> Hi!, i'm a new user of Mapbender and i have a problem, my initial .map
>> file ,
>> have a imagecolor of backgroud blue, and when i got the wms services op
>> the
>> mapfile and draw it whith mapbender, the backgroundcolor of my map it's
>> white.
>> What can i do?   %-|
>> Sorry for my english
>> Thank You very Much!!
>> View this message in context:
>> http://www.nabble.com/Mapserver-Imagecolor-tp16964260p16964260.html
>> Sent from the mapbender-users mailing list archive at Nabble.com.
>> Mapbender_users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
