[Mapbender-users] BBOX problem
Victor Moral
vmoral at fundacionchile.cl
Thu May 8 19:04:46 EDT 2008
Thx for your answer Michael!
but....
- The "base" layer is the first on the gui (with id 0) but it doesn't
start within this extent
- I've had also tried including
"mb_myBBOX=160016,6708673,666976,7226699" in the url without results.
- The element set_BBOX is also activated in the GUI.
What is missing? Do you want to log into the admin gui?
vm
Víctor Moral M.
Ingeniero de Proyectos
Area Medio Ambiente y Energía
Fundación Chile
Avda. Parque Antonio Rabat Sur 6165 - Vitacura
Tel: 56-2-2400648
www.fundacionchile.cl
Michael Schulz wrote:
> Hi Victor,
> in order to start a gui with a certain bbox (different from the extent
> of the first wms in the gui, that's the default extent) you need the
> additional starturl parameter mb_myBBOX=xmin,ymin,xmax,ymax and you
> need to activate the module set_bbox1 for this gui.
> HTH, Michael
> 2008/5/8 Victor Moral <vmoral at fundacionchile.cl>:
>> Hi there!
>> i'm working on my first deployment of mapbender over mapserver/postgis.
>> Everything works great and i'm getting a superb performance from mapbender.
>> The only problem i got is trying to set the initial BBOX for mapbender
>> after the login. I've tried everything that i found published about this
>> functionality, but i spend too much time without results.
>> This test deployment, based on the gui2 shipped example, is running at :
>> http://200.75.22.90/mapbender/frames/login.php?name=toresa&password=toresalink
>> I need MB to start "zoomed at" the "base" layer.
>> Any clues?
>> Thx !
>> vm
>> Víctor Moral M.
>> Fundación Chile
>> Tel: 56-2-2400648
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
