[Mapbender-users] MB 2.5 RC2 - treeGDE/featureinfo1 - 2nd
Michael Schulz
mschulz at webgis.de
Thu May 15 08:18:03 EDT 2008
Hi Ronald,
yes, I have the same issue. It seems querying is working ok, if a
layer has sel_default and info_default set to on. If only sel_default
is on and info_default is off, just checking the featureinfo checkbox
in treegde does not enable querying: "please select a layer"
Since you reported this bug could you create a ticket for it?
Thanks, Michael
2008/4/24 Ronald Woita <Ronald.Woita at rostock.de>:
> ah, i forgot the second part :-(
> if someone proves this behaviour I will open a new issue in Mapbender
> Bug Tracker for it.
> Ronald
> >>> Ronald.Woita at rostock.de 24.04.2008 11:07:10 >>>
> hi list,
> i experienced a strange behaviour with modules treeGDE and
> featureinfo1.
> ( ficheckbox = true )
> To make a featureinforequest i have to select a layer in the order
> first getfeatureinfo-checkbox then getmap-checkbox.
> In reverse (and usual) order it does'nt work.
> If 'ficheckbox = false' then nothing humppa.
> Mapbender-2.5RC2 /UTF-8
> PostgreSQL 8.3.1
> PHP 5.2.5
> regards
> Ronald
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users
