AW: [Mapbender-users] MB 2.5: Problem with module MonitorCapabilities
Schönhammer, Herbert Schoenhammer.Herbert at Regensburg.de
Wed Nov 26 05:25:12 EST 2008
Hi Mr. Schulz,
thanks for the tipp.
( yes, I had a lot of trouble with php: first i had no cli compiled, then another php.ini for cli is used as for the apache-modul, ...)
I thought, I had solved all those troubles. But unfortenately I did not see, that in mod_monitorCapabilities_main line 150 the "php5" is used.
On my server "php5" was indeed another php-version. Okay problem solved. The WMS are monitored. This problem is solved.
But there are new error messages now (which have no effect for monitoring the wms) . I get (a hundred times ;-) ) the messages:
PHP Warning:  Missing argument 4 for Mapbender_point::__construct(), called in /home/mapbender/mapbender_2.5/http/classes/class_point.php on line 116 and defined in /home/mapbender/mapbender_2.5/http/classes/class_point.php on line 34
greetings
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Michael Schulz
>Gesendet: Mittwoch, 26. November 2008 10:41
>An: Mapbender User List
>Betreff: Re: [Mapbender-users] MB 2.5: Problem with module
>MonitorCapabilities
>Hi Mr. Schönhammer,
>just a wild guess: monitorCapabilities_main uses the commandline php
>to actually call monitorCapabilites_write, if you get an undefined
>function error this sounds like the cli php that is used, differs from
>the one that is used for mapbender via apache cgi or module. Could
>that be the case?
>Have a look at mod_monitorCapabilities_main line 150, there the
>command line is constructed, the PHP_PATH is set in mapbender.conf. If
>you call this "PHP_PATH php -v" from the shell you'll get the used php
>version.
>Greetings, Michael Schulz
>2008/11/26 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
>> Hi list,
>> At this point of time I'm using MB 2.4.1. The module
>MonitorCapabilities is
>> working well.
>> Now I want to use the module MonitorCapabilites with MB 2.5.
>> I start the monitoring process with:  php
>./mod_monitorCapabilities_main.php
>> user:root gui:xyz
>> The script reports a fatal error: call to undefined function
>> mb_internal_encoding() in
>> /home/mapbender/mapbender_2.5/core/globalSettings.php on line 22.
>> All WMS are reported as "Monitoring process timed out". But
>(of course) they
>> are reachable !
>> Records in table mb_monitor are stored. But there is
>obviously a problem
>> getting the capabilities-document. The server's access_log
>does NOT report a
>> getcapabilites-request.
>> Has anyone an idea what to do ?
>> greetings
>> The complete otuput of ./mod_monitorCapabilities_main.php  is:
>> Starting monitoring cycle...
>> WMS services are requested for availability.
>> Capabilities documents are requested and all changes
>synchronized with the
>> database cache.
>> PHP Notice:  A session had already been started - ignoring
>session_start()
>> in /home/mapbender/mapbender_2.5/core/globalSettings.php on line 22
>> PHP Fatal error:  Call to undefined function
>> /home/mapbender/mapbender_2.5/core/globalSettings.php on line 27
>session_start()
>session_start()
>session_start()
>session_start()
>session_start()
>session_start()
>> Monitoring Cycle completed (total: 8 wms).
>> please wait 300 seconds for the monitoring to finish...
>session_start()
>> 912: status -1
>> 913: status -1
>> 916: status -1
>> 929: status -1
>> 930: status -1
>> 931: status -1
>> 934: status -1
>> 937: status -1
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>Michael Schulz
>mschulz at webgis.de
>in medias res
>Gesellschaft für Informationstechnologie mbH
>In den Weihermatten 66
>79108 Freiburg
>Tel  +49 (0)761 556959-5
>Fax +49 (0)761 556959-6
>http://www.webgis.de / http://www.zopecms.de
>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
