[Mapbender-users] minscale and maxscale problem
Raivo Alla
snaperski at gmail.com
Thu Nov 27 05:00:58 EST 2008
i am using mapbender version 2.4.2 and have following problem:
in the mapfile I defined scales under LAYER section like that:
MAXSCALE 200000
MINSCALE 50000
and on the MAP section
PROJECTION
"init=epsg:3301"
END
Next, when I look at EDIT GUI-WMS in Mapbender at admin1, then
there's EPSG 4326 and when I change it to EPSG 3301, then map works
fine, but min and maxscales are corrupted: for example maxscale 200000
becomes maxscale 150000 and minscale 50000 becomes minscale 37500.
Actually, when i run Load WMS GetCapabilities request, then it
already shows wrong scale numbers.
What to do?
Sincerly,
Raivo
More information about the Mapbender_users
