[Mapbender-users] Query Parameter for a specific external WMS
gisbert.breitbach at gkss.de
Fri Oct 31 05:08:54 EDT 2008
Many, many thanks,
you found the error. Now I can try to go on.
Gisbert
____________________________________________________
Gisbert Breitbach, GKSS Forschungszentrum
Tel.: +49 4152 87 1563
Fax: +49 4152 87 4 1563
E-Mail: Gisbert.Breitbach at gkss.de
"Michael Schulz" <mschulz at webgis.de>
Sent by: mandschulz at googlemail.com
31.10.2008 09:54
To
"Mapbender User List" <mapbender_users at lists.osgeo.org>
cc
Subject
Re: [Mapbender-users] Query Parameter for a specific external WMS
Hi Gisbert,
I just had a look at the testmitaddvendor GUI: there is a JS error:
unterminated string literal. Could you please check your
mod_addvendorspecific.php module? It seems there is an additional php
end block:
snippet:
else{var
posMin=makeClickPos2RealWorldPos(mb_isBF,minx,miny);ret[0]=posMin[0];ret[1]=posMin[1];return
ret;}}";
mb_registerVendorSpecific("mod_vs_init()");
function mod_vs_init(){
var re = "vendorspecific=test";
return re;
Second line of the snippet, the "?>", should not be present, and I
think it stems from your mod_addvendorspecific.
Cheers, Michael
2008/10/30 <gisbert.breitbach at gkss.de>:
> Sorry, this is a firewall problem. It will be solved tomorrow.
> Gisbert
> mandschulz at googlemail.com wrote on 30.10.2008 17:26:47:
>> Hi,
>> sorry, but I can't reach the URL, connection timed out ...
>> Michael
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
