AW: AW: [Mapbender-users] MB 2.5: Problems with legends in
pdf-print using mapserver's agg
Schönhammer, Herbert
Schoenhammer.Herbert at Regensburg.de
Thu Apr 30 02:44:53 EDT 2009
Hi Armin,
I made some tests: Using
$output = $this->set("format","image/png; mode=24bit");
instead of
$output = $this->set("format","image/png");
I get this result:
- the legend is okay
- but he mapframe of the print is only white; no error message
I give up;
I will switch the background of the legend-module in all gui's to white;
=> the legend-background of mapserver's legend could also be white
=> the print is okay
=> but the appearance of all guis is not okay :-(
But the better map-quality offered by agg should be a reason for doing that !
Thanks to all, which gave me some hints for troubleshooting.
regards
Herbert
P:S: I will close the "Printtest"-gui in a few days.
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Armin Retterath
>Gesendet: Mittwoch, 29. April 2009 16:13
>An: Mapbender User List
>Betreff: Re: AW: [Mapbender-users] MB 2.5: Problems with
>legends in pdf-print using mapserver's agg
>hello herbert,
>i think, that mb_log logs only the requests, that are done by
>the client
>itself. the printing of the maps is done by getting the
>pictures with curl or
>http. there are 2 classes classes/weldMaps2PNG.php and and
>classes/class_stripRequest.php.
>in class_stripRequest.php there is a function setPNG()
>change it for testing.
>one problem: if you use curl for doing the request you must adopt
>class_connector.php, cause curl have problems with 'image/png; mode=
>24bit' in urls - i've got a adopted one if you need it. ;-)
>greetings
>armin
>Am Mittwoch 29 April 2009 14:56:37 schrieb Schönhammer, Herbert:
>> Hi Michael,
>> Hi list,
>> I'm back again with (nearly) the same problem ;-)
>> Now I've got a server, reachable from Internet. I wanted to
>build a gui for
>> testing the troubles. But with some further trial and error I found a
>> combination of mapserver/agg-parameters and
>mapbender-parameters which are
>> avoiding the described problem.
>> But now I have another problem in printing the map (please
>see below !)
>> First things, which are doing right now:
>> In my MAPFILE I'm using now:
>> # 24 Bit Farbe
>> OUTPUTFORMAT
>> NAME 'AGGA'
>> #MIMETYPE 'image/png' <======= you MUST NOT
>use the MIMETYPE
>> attribute !!!! DRIVER AGG/PNG
>> EXTENSION PNG
>> IMAGEMODE RGBA
>> END
>> LEGEND
>> STATUS ON
>> KEYSIZE 30 20
>> KEYSPACING 10 5
>> LABEL
>> COLOR 0 0 0
>> TYPE TRUETYPE
>> FONT "verdana"
>> SIZE 8
>> END
>> TRANSPARENT ON
>> IMAGECOLOR 255 255 255
>> END
>> In mapbender wms-gui settings I use:
>> "image/png; mode=24bit" for this wms
>> The result is
>> I have a map with good quality ON THE SCREEN, the legend ON
>THE SCREEN is
>> okay (has transparent background) AND THE LEGEND ON THE
>PRINT IS OKAY NOW
>> (the legend has also a transparent background).
>> The new problem is:
>> Now the quality in the MAP of the print is poor. It seems, that the
>> print-module is ignoring the mapbender-setting "image/png;
>mode=24bit".
>> In detail:
>> In mb_log the following request is logged as request for
>printing (I have
>> replaced ' ' through '%20' because the server is online; you
>may try the
>> requests !!):
>http://stadtplan2.regensburg.de/cgi-bin/getows?map=/cityportal-
>maps/rgb_pri
>>nttest-agg24.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYE
>RS=strassenach
>>sen&STYLES=&SRS=EPSG:31468&BBOX=4506700.1038532015,5431380.999
>99632,4506868.
>>999796765,5431617.833858754&WIDTH=1780&HEIGHT=2496&FORMAT=imag
>e/png;%20mode=
>>24bit&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application
>/vnd.ogc.se_in
>>image
>> The request above delivers the correct image with good
>quality in 24bit
>> color.
>> But in webservers-log all requests for printing DO NOT use
>the "image/png;
>> mode=24bit". They only use "image/png". The corresponding line in
>> apache-log is: 192.168.2.16 - - [29/Apr/2009:14:03:13 +0200] "GET
>/cgi-bin/getows?map=/cityportal-maps/rgb_printtest-agg24.map&VE
>RSION=1.1.1&
>>REQUEST=GetMap&SERVICE=WMS&LAYERS=strassenachsen&STYLES=&SRS=E
>PSG:31468&BBOX
>>=4506700.1038532015,5431380.99999632,4506868.999796765,5431617
>.833858754&WID
>>TH=1780&HEIGHT=2496&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPAR
>ENT=TRUE&EXCEP
>>TIONS=application/vnd.ogc.se_inimage HTTP/1.0" 200 37121 "-" "-"
>> for trying:
>maps/rgb_pri
>RS=strassenach
>99632,4506868.
>e/png&BGCOLOR=
>>0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
>> The request above delivers poor quality in 8bit color, which
>is used for
>> printing !!!
>> Obviously the logged map-request in mb_log differs from the
>map-requests
>> sent to the webserver !?!?!
>> Tipps for me ?
>> Does anybody know where
>> - the map-requests for printing are created ?
>> - the map-requests for logging are created ?
>> - the getlegendgraphic-requests for printing are created ?
>> How to ensure, that the mapbender settings for mapformat are
>also used for
>> printing ?
>> I'm using MB 2.5 !!
>> (If you want to make your own trials, this gui is now online
>for testing:
>http://stadtplan2.regensburg.de/mb25/frames/login.php?name=stad
>tplan&passwo
>>rd=stadtplan&mb_user_myGui=Printtest )
>> Thanks a lot
>> greetings
>> Herbert
>> >von Michael Schulz
>> >Gesendet: Dienstag, 3. März 2009 14:05
>> >Betreff: Re: [Mapbender-users] MB 2.5: Problems with legends
>> >Hi Herbert,
>> >I am somewhat at the end of my latin ;-)
>> >class_SaveLegend should create a white background rectangle in each
>> >created legend image. If I remember correctly your using
>the RGBA mode
>> >in your outputformat. Could you try with only RGB? Maybe
>the pdf class
>> >image functions cannot handle alpha channel transparency.
>> >Cheers, Michael
>> >2009/3/3 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
>> >> Hi Michael,
>> >> (sorry today and tomorrow I have a lot of dates :-(, so i'm
>> >late to answer ! )
>> >> following your hints, I'm observing following:
>> >> 1) I'm using again: image/png as wms setting
>> >> 2) $unlink=false: The png -file of the legend-picture is a
>> >24 bit picture with the wrong (=black) background-color
>> >> 3) Looking at apache-log mapbender's
>> >getlegendgraphic-request uses "image/png"
>> >> 4) Taking the request from apache-log and sending this
>> >request to mapserver: the picture comes with transparent
>> >background (like it should be) as a 24 bit png !
>> >> => The request from mapbender to mapserver has a correct 24
>> >bit png as result
>> >> => The temporary file in the tmp- directory is also a 24bit
>> >png, but with wrong background color
>> >> => This wrong (black) png is inc´luded into the generated pdf !
>> >> P.S: I'm not able to give you access to the services. From
>> >Internet they will be rechable next weak !
>> >> regards
>> >> Herbert
>> >>>von Michael Schulz
>> >>>Gesendet: Montag, 2. März 2009 17:57
>> >>>Hi,
>> >>>the problem with 24bit rendering is, that mapserver
>publishes that as
>> >>>"image/png;mode=24bit" in the wms getcapabilities if you
>don't define
>> >>>a special outputformat. So, when you have set image/png as
>> >>>image-format in mapbender and you get a 24bit png back
>everything is
>> >>>perfect.
>> >>>Have you tried setting $unlink=false in printPDF.conf and
>> >then examine
>> >>>the temporary images while generating the pdf output? I
>am not sure,
>> >>>if this has impact on the legend images, but it could be
>worth a try.
>> >>>Cheers, Michael
>> >>>2009/3/2 Schönhammer, Herbert
>> >>>> Hi Michael,
>> >>>> sorry I don't really understand your hint :-(
>> >>>> At the moment I use (wms-gui-settings): "image/png"
>> >>>> But there is no difference between "image/png" and
>> >>>"image/png; mode=24bit".
>> >>>> Only the settings in the mapfile determine the outputformat.
>> >>>So the following always generates a 8bit output. In this case,
>> >>>the printig of the picture in the legend is okay, but the
>> >>>quality of the map is very very poor.
>> >>>> # 8 Bit Farbe
>> >>>> OUTPUTFORMAT
>> >>>> NAME 'AGG_Q'
>> >>>> DRIVER AGG/PNG
>> >>>> IMAGEMODE RGB
>> >>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> >>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> >>>> FORMATOPTION "QUANTIZE_COLORS=256"
>> >>>> END
>> >>>> So I want a map with 24bit color.
>> >>>> Please: Could you give me some more hints?
>> >>>> What shall I use ? "image/png" or "image/png; mode=24bit" in
>> >>>wms-settings?
>> >>>> What settings in the mapfile should be done in this case ?
>> >>>> regards
>> >>>> Herbert Schönhammer
>> >>>>>von Michael Schulz
>> >>>>>Gesendet: Montag, 2. März 2009 14:39
>> >>>>>Hello Mr. Schönhammer,
>> >>>>>are you using imagemode "image/png;24bit mode" for this
>service in
>> >>>>>Mapbender? Then this could be the problem, because
>> >printPDF sets the
>> >>>>>imageformat for the maps and the legend icons to image/png.
>> >>>Then maybe
>> >>>>>your customized outputformat isn't used anymore... In
>the GUI the
>> >>>>>imageformats are used as defined in gui wms settings.
>> >>>>>Chees, Michael Schulz
>> >>>>>> Hi list,
>> >>>>>> I have a new strange problem with pdf-print in Mapbender 2.5.
>> >>>>>> Lines should be rendered with rounded linejoins. So I'm
>> >>>>>using mapserver agg
>> >>>>>> - renderer with an outputformat defined like:
>> >>>>>> OUTPUTFORMAT
>> >>>>>> ##NAME png
>> >>>>>> ##DRIVER "GD/PNG"
>> >>>>>> MIMETYPE "image/png"
>> >>>>>> NAME 'AGGA'
>> >>>>>> DRIVER AGG/PNG
>> >>>>>> EXTENSION PNG
>> >>>>>> IMAGEMODE RGBA
>> >>>>>> TRANSPARENT ON
>> >>>>>> END
>> >>>>>> Things are done well
>> >>>>>> in the map
>> >>>>>> and in the legend of the gui.
>> >>>>>> Things are going wrong in printing the legend in pdf-print.
>> >>>>>> The legend picture is drawn with a black background. So the
>> >>>>>text of the
>> >>>>>> legend is not readable anymore. (Please see examples in
>> >>>the appendix)
>> >>>>>> Until now I used gd-driver. With gd-driver all things are
>> >>>>>going right.
>> >>>>>> The background of the legend picture is defined transparent.
>> >>>>>So the same
>> >>>>>> legend picture my be used in different guis (with different
>> >>>>>> background-color) and in pdf-Print.
>> >>>>>> LEGEND
>> >>>>>> STATUS ON
>> >>>>>> KEYSIZE 298 398
>> >>>>>> KEYSPACING 10 1
>> >>>>>> LABEL
>> >>>>>> TYPE TRUETYPE
>> >>>>>> FONT "verdana"
>> >>>>>> SIZE 8
>> >>>>>> POSITION lc
>> >>>>>> END # END LABEL
>> >>>>>> TRANSPARENT ON
>> >>>>>> END #LEGEND
>> >>>>>> I'm not able to detect any difference in the pictures
>> >>>>>produced by gd or by
>> >>>>>> agg. In all tools (even photo-editors) the background is
>> >displayed
>> >>>>>> transparent. Only in mapbender pdf-print the background is
>> >>>>>displayed in
>> >>>>>> black. So I think, the solution could be in pdf-print ?
>> >>>>>> Has anybody observed similar problems ?
>> >>>>>> Has anybody a tipp ?
>> >>>>>> Thanks a lot
>> >>>>>> Herbert Schönhammer
>> >>>>>> _______________________________________________
>> >>>>>> Mapbender_users mailing list
>> >>>>>> Mapbender_users at lists.osgeo.org
>> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> >>>>>Michael Schulz
>> >>>>>mschulz at webgis.de
>> >>>>>in medias res
>> >>>>>Gesellschaft für Informationstechnologie mbH
>> >>>>>In den Weihermatten 66
>> >>>>>79108 Freiburg
>> >>>>>Tel +49 (0)761 556959-5
>> >>>>>Fax +49 (0)761 556959-6
>> >>>>>http://www.webgis.de / http://www.zopecms.de
>> >>>>>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>> >>>>>Eingetragen im Handelsregister HRB 5930 beim
>Amtsgericht Freiburg
>> >>>Michael Schulz
>> >>>in medias res
>> >>>79108 Freiburg
>> >>>Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>> >Michael Schulz
>> >in medias res
>> >79108 Freiburg
>Im Auftrag
>Armin Retterath
>Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
>beim
>Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
>Ferdinand-Sauerbruch-Straße 15
>56073 Koblenz
>Telefon 0261/492-466
>Telefax 0261/492-492
>armin.retterath at lvermgeo.rlp.de
>http://www.geoportal.rlp.de
More information about the Mapbender_users
