AW: [Mapbender-users] MB 2.5: Problems with legends in pdf-print
using mapserver's agg
Schönhammer, Herbert
Schoenhammer.Herbert at Regensburg.de
Thu Apr 30 10:12:12 EDT 2009
Hi Armin,
thank you for your tipps.
Until now i use "http"-connections.
I think for using curl-connection, php should be compiled with options "--with-curl" and "--with-curlwrappers" ?
I recompiled php with these options. In mapbender.conf I changed my settings to
# type of server-connection
# curl, socket, http
define("CONNECTION", "curl");
#define("CONNECTION", "http");
#define("CONNECTION", "socket");
Is that all I should do for using curl connections ?
Trying to print something, I don't get png from the server. Only several error messages like (I did not change the class connector yet. I tried to use the class connector of the MB 2.5 distribution !):
- in mb_error_log:
2009.04.30, 16:02:14,ERROR: SaveLegend: unable to load image: http://stadtplan2.regensburg.de/cgi-bin/getows?map=/cityportal-maps/rgb_printtest-agg24.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=strassenachsen&format=image/png&STYLE=default
- in apache-log:
[Thu Apr 30 16:02:14 2009] [error] [client 192.168.2.3] PHP Warning: imagepng(): supplied argument is not a valid Image resource in /home/mapbender/mapbender_2.5/http/classes/class_SaveLegend.php on line 51, referer: http://stadtplan2.regensburg.de/mb25/print/mod_printPDF_rgb.php?target=mapframe1&&guiID=Printtest&elementID=printPDF&conf=printPDF_b_stpl07_rgb.conf
[Thu Apr 30 16:02:14 2009] [error] [client 192.168.2.3] PHP Warning: imagedestroy(): supplied argument is not a valid Image resource in /home/mapbender/mapbender_2.5/http/classes/class_SaveLegend.php on line 52, referer: http://stadtplan2.regensburg.de/mb25/print/mod_printPDF_rgb.php?target=mapframe1&&guiID=Printtest&elementID=printPDF&conf=printPDF_b_stpl07_rgb.conf
[Thu Apr 30 16:02:14 2009] [error] [client 192.168.2.3] PHP Warning: getimagesize(../tmp/legend_49f44bb.png) [<a href='function.getimagesize'>function.getimagesize</a>]: failed to open stream: Datei oder Verzeichnis nicht gefunden in /home/mapbender/mapbender_2.5/http/print/mod_printPDF_pdf_rgb.php on line 826, referer: http://stadtplan2.regensburg.de/mb25/print/mod_printPDF_rgb.php?target=mapframe1&&guiID=Printtest&elementID=printPDF&conf=printPDF_b_stpl07_rgb.conf
Okay, I use "http"-connection again !
regards
Herbert
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Armin Retterath
>Gesendet: Donnerstag, 30. April 2009 13:04
>An: Mapbender User List
>Betreff: Re: AW: AW: [Mapbender-users] MB 2.5: Problems with
>legends in pdf-print using mapserver's agg
>Hi Herbert,
>look at this function in class connector (if you use the curl
>option in
>mapbender):
>private function getCURL($url){
> $url=Str_replace(" ","+",$url);
> $url=str_replace(";","%3B",$url);
> $ch = curl_init ($url);
> curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
> curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
> curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
> if(CONNECTION_PROXY != ""){
> curl_setopt($ch,
>CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
> if(CONNECTION_PASSWORD != ""){
> curl_setopt ($ch, CURLOPT_PROXYUSERPWD,
>CONNECTION_USER.':'.CONNECTION_PASSWORD);
> curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
> $useragent='GeoPortal Rheinland-Pfalz';
> curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
> $file = curl_exec ($ch);
> curl_close ($ch);
> return $file;
>The 3. row defines a replacement for ; - this may be your
>problem - exchange
>this function and test it. (replace the $useragent - if you like ;-))
>Greetings
>Armin
>Am Donnerstag 30 April 2009 08:44:53 schrieb Schönhammer, Herbert:
>> Hi Armin,
>> I made some tests: Using
>> $output = $this->set("format","image/png; mode=24bit");
>> instead of
>> $output = $this->set("format","image/png");
>> I get this result:
>> - the legend is okay
>> - but he mapframe of the print is only white; no error message
>> I give up;
>> I will switch the background of the legend-module in all
>gui's to white;
>> => the legend-background of mapserver's legend could also be white
>> => the print is okay
>> => but the appearance of all guis is not okay :-(
>> But the better map-quality offered by agg should be a reason
>for doing that
>> Thanks to all, which gave me some hints for troubleshooting.
>> regards
>> Herbert
>> P:S: I will close the "Printtest"-gui in a few days.
>> >von Armin Retterath
>> >Gesendet: Mittwoch, 29. April 2009 16:13
>> >Betreff: Re: AW: [Mapbender-users] MB 2.5: Problems with
>> >hello herbert,
>> >i think, that mb_log logs only the requests, that are done by
>> >the client
>> >itself. the printing of the maps is done by getting the
>> >pictures with curl or
>> >http. there are 2 classes classes/weldMaps2PNG.php and and
>> >classes/class_stripRequest.php.
>> >in class_stripRequest.php there is a function setPNG()
>> >change it for testing.
>> >one problem: if you use curl for doing the request you must adopt
>> >class_connector.php, cause curl have problems with 'image/png; mode=
>> >24bit' in urls - i've got a adopted one if you need it. ;-)
>> >greetings
>> >armin
>> >Am Mittwoch 29 April 2009 14:56:37 schrieb Schönhammer, Herbert:
>> >> Hi Michael,
>> >> Hi list,
>> >> I'm back again with (nearly) the same problem ;-)
>> >> Now I've got a server, reachable from Internet. I wanted to
>> >build a gui for
>> >> testing the troubles. But with some further trial and
>error I found a
>> >> combination of mapserver/agg-parameters and
>> >mapbender-parameters which are
>> >> avoiding the described problem.
>> >> But now I have another problem in printing the map (please
>> >see below !)
>> >> First things, which are doing right now:
>> >> In my MAPFILE I'm using now:
>> >> # 24 Bit Farbe
>> >> OUTPUTFORMAT
>> >> NAME 'AGGA'
>> >> #MIMETYPE 'image/png' <======= you MUST NOT
>> >use the MIMETYPE
>> >> attribute !!!! DRIVER AGG/PNG
>> >> EXTENSION PNG
>> >> IMAGEMODE RGBA
>> >> END
>> >> LEGEND
>> >> STATUS ON
>> >> KEYSIZE 30 20
>> >> KEYSPACING 10 5
>> >> LABEL
>> >> COLOR 0 0 0
>> >> TYPE TRUETYPE
>> >> FONT "verdana"
>> >> SIZE 8
>> >> END
>> >> TRANSPARENT ON
>> >> IMAGECOLOR 255 255 255
>> >> END
>> >> In mapbender wms-gui settings I use:
>> >> "image/png; mode=24bit" for this wms
>> >> The result is
>> >> I have a map with good quality ON THE SCREEN, the legend ON
>> >THE SCREEN is
>> >> okay (has transparent background) AND THE LEGEND ON THE
>> >PRINT IS OKAY NOW
>> >> (the legend has also a transparent background).
>> >> The new problem is:
>> >> Now the quality in the MAP of the print is poor. It
>seems, that the
>> >> print-module is ignoring the mapbender-setting "image/png;
>> >mode=24bit".
>> >> In detail:
>> >> In mb_log the following request is logged as request for
>> >printing (I have
>> >> replaced ' ' through '%20' because the server is online; you
>> >may try the
>> >> requests !!):
>> >maps/rgb_pri
>> >>nttest-agg24.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYE
>> >RS=strassenach
>> >>sen&STYLES=&SRS=EPSG:31468&BBOX=4506700.1038532015,5431380.999
>> >99632,4506868.
>> >>999796765,5431617.833858754&WIDTH=1780&HEIGHT=2496&FORMAT=imag
>> >e/png;%20mode=
>> >>24bit&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application
>> >/vnd.ogc.se_in
>> >>image
>> >> The request above delivers the correct image with good
>> >quality in 24bit
>> >> color.
>> >> But in webservers-log all requests for printing DO NOT use
>> >the "image/png;
>> >> mode=24bit". They only use "image/png". The corresponding line in
>> >> apache-log is: 192.168.2.16 - - [29/Apr/2009:14:03:13 +0200] "GET
>> >/cgi-bin/getows?map=/cityportal-maps/rgb_printtest-agg24.map&VE
>> >RSION=1.1.1&
>> >>REQUEST=GetMap&SERVICE=WMS&LAYERS=strassenachsen&STYLES=&SRS=E
>> >PSG:31468&BBOX
>> >>=4506700.1038532015,5431380.99999632,4506868.999796765,5431617
>> >.833858754&WID
>> >>TH=1780&HEIGHT=2496&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPAR
>> >ENT=TRUE&EXCEP
>> >>TIONS=application/vnd.ogc.se_inimage HTTP/1.0" 200 37121 "-" "-"
>> >> for trying:
>> >maps/rgb_pri
>> >RS=strassenach
>> >99632,4506868.
>> >e/png&BGCOLOR=
>> >>0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
>> >> The request above delivers poor quality in 8bit color, which
>> >is used for
>> >> printing !!!
>> >> Obviously the logged map-request in mb_log differs from the
>> >map-requests
>> >> sent to the webserver !?!?!
>> >> Tipps for me ?
>> >> Does anybody know where
>> >> - the map-requests for printing are created ?
>> >> - the map-requests for logging are created ?
>> >> - the getlegendgraphic-requests for printing are created ?
>> >> How to ensure, that the mapbender settings for mapformat are
>> >also used for
>> >> printing ?
>> >> I'm using MB 2.5 !!
>> >> (If you want to make your own trials, this gui is now online
>> >for testing:
>> >http://stadtplan2.regensburg.de/mb25/frames/login.php?name=stad
>> >tplan&passwo
>> >>rd=stadtplan&mb_user_myGui=Printtest )
>> >> Thanks a lot
>> >> greetings
>> >> Herbert
>> >> >von Michael Schulz
>> >> >Gesendet: Dienstag, 3. März 2009 14:05
>> >> >Betreff: Re: [Mapbender-users] MB 2.5: Problems with legends
>> >> >Hi Herbert,
>> >> >I am somewhat at the end of my latin ;-)
>> >> >class_SaveLegend should create a white background
>rectangle in each
>> >> >created legend image. If I remember correctly your using
>> >the RGBA mode
>> >> >in your outputformat. Could you try with only RGB? Maybe
>> >the pdf class
>> >> >image functions cannot handle alpha channel transparency.
>> >> >Cheers, Michael
>> >> >2009/3/3 Schönhammer, Herbert
><Schoenhammer.Herbert at regensburg.de>:
>> >> >> Hi Michael,
>> >> >> (sorry today and tomorrow I have a lot of dates :-(, so i'm
>> >> >late to answer ! )
>> >> >> following your hints, I'm observing following:
>> >> >> 1) I'm using again: image/png as wms setting
>> >> >> 2) $unlink=false: The png -file of the legend-picture is a
>> >> >24 bit picture with the wrong (=black) background-color
>> >> >> 3) Looking at apache-log mapbender's
>> >> >getlegendgraphic-request uses "image/png"
>> >> >> 4) Taking the request from apache-log and sending this
>> >> >request to mapserver: the picture comes with transparent
>> >> >background (like it should be) as a 24 bit png !
>> >> >> => The request from mapbender to mapserver has a correct 24
>> >> >bit png as result
>> >> >> => The temporary file in the tmp- directory is also a 24bit
>> >> >png, but with wrong background color
>> >> >> => This wrong (black) png is inc´luded into the generated pdf !
>> >> >> P.S: I'm not able to give you access to the services. From
>> >> >Internet they will be rechable next weak !
>> >> >> regards
>> >> >> Herbert
>> >> >>>von Michael Schulz
>> >> >>>Gesendet: Montag, 2. März 2009 17:57
>> >> >>>Hi,
>> >> >>>the problem with 24bit rendering is, that mapserver
>> >publishes that as
>> >> >>>"image/png;mode=24bit" in the wms getcapabilities if you
>> >don't define
>> >> >>>a special outputformat. So, when you have set image/png as
>> >> >>>image-format in mapbender and you get a 24bit png back
>> >everything is
>> >> >>>perfect.
>> >> >>>Have you tried setting $unlink=false in printPDF.conf and
>> >> >then examine
>> >> >>>the temporary images while generating the pdf output? I
>> >am not sure,
>> >> >>>if this has impact on the legend images, but it could be
>> >worth a try.
>> >> >>>Cheers, Michael
>> >> >>>2009/3/2 Schönhammer, Herbert
>> >> >>>> Hi Michael,
>> >> >>>> sorry I don't really understand your hint :-(
>> >> >>>> At the moment I use (wms-gui-settings): "image/png"
>> >> >>>> But there is no difference between "image/png" and
>> >> >>>"image/png; mode=24bit".
>> >> >>>> Only the settings in the mapfile determine the outputformat.
>> >> >>>So the following always generates a 8bit output. In this case,
>> >> >>>the printig of the picture in the legend is okay, but the
>> >> >>>quality of the map is very very poor.
>> >> >>>> # 8 Bit Farbe
>> >> >>>> OUTPUTFORMAT
>> >> >>>> NAME 'AGG_Q'
>> >> >>>> DRIVER AGG/PNG
>> >> >>>> IMAGEMODE RGB
>> >> >>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> >> >>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> >> >>>> FORMATOPTION "QUANTIZE_COLORS=256"
>> >> >>>> END
>> >> >>>> So I want a map with 24bit color.
>> >> >>>> Please: Could you give me some more hints?
>> >> >>>> What shall I use ? "image/png" or "image/png; mode=24bit" in
>> >> >>>wms-settings?
>> >> >>>> What settings in the mapfile should be done in this case ?
>> >> >>>> regards
>> >> >>>> Herbert Schönhammer
>> >> >>>>>von Michael Schulz
>> >> >>>>>Gesendet: Montag, 2. März 2009 14:39
>> >> >>>>>Hello Mr. Schönhammer,
>> >> >>>>>are you using imagemode "image/png;24bit mode" for this
>> >service in
>> >> >>>>>Mapbender? Then this could be the problem, because
>> >> >printPDF sets the
>> >> >>>>>imageformat for the maps and the legend icons to image/png.
>> >> >>>Then maybe
>> >> >>>>>your customized outputformat isn't used anymore... In
>> >the GUI the
>> >> >>>>>imageformats are used as defined in gui wms settings.
>> >> >>>>>Chees, Michael Schulz
>> >> >>>>>> Hi list,
>> >> >>>>>> I have a new strange problem with pdf-print in
>Mapbender 2.5.
>> >> >>>>>> Lines should be rendered with rounded linejoins. So I'm
>> >> >>>>>using mapserver agg
>> >> >>>>>> - renderer with an outputformat defined like:
>> >> >>>>>> OUTPUTFORMAT
>> >> >>>>>> ##NAME png
>> >> >>>>>> ##DRIVER "GD/PNG"
>> >> >>>>>> MIMETYPE "image/png"
>> >> >>>>>> NAME 'AGGA'
>> >> >>>>>> DRIVER AGG/PNG
>> >> >>>>>> EXTENSION PNG
>> >> >>>>>> IMAGEMODE RGBA
>> >> >>>>>> TRANSPARENT ON
>> >> >>>>>> END
>> >> >>>>>> Things are done well
>> >> >>>>>> in the map
>> >> >>>>>> and in the legend of the gui.
>> >> >>>>>> Things are going wrong in printing the legend in pdf-print.
>> >> >>>>>> The legend picture is drawn with a black background. So the
>> >> >>>>>text of the
>> >> >>>>>> legend is not readable anymore. (Please see examples in
>> >> >>>the appendix)
>> >> >>>>>> Until now I used gd-driver. With gd-driver all things are
>> >> >>>>>going right.
>> >> >>>>>> The background of the legend picture is defined
>transparent.
>> >> >>>>>So the same
>> >> >>>>>> legend picture my be used in different guis (with different
>> >> >>>>>> background-color) and in pdf-Print.
>> >> >>>>>> LEGEND
>> >> >>>>>> STATUS ON
>> >> >>>>>> KEYSIZE 298 398
>> >> >>>>>> KEYSPACING 10 1
>> >> >>>>>> LABEL
>> >> >>>>>> TYPE TRUETYPE
>> >> >>>>>> FONT "verdana"
>> >> >>>>>> SIZE 8
>> >> >>>>>> POSITION lc
>> >> >>>>>> END # END LABEL
>> >> >>>>>> TRANSPARENT ON
>> >> >>>>>> END #LEGEND
>> >> >>>>>> I'm not able to detect any difference in the pictures
>> >> >>>>>produced by gd or by
>> >> >>>>>> agg. In all tools (even photo-editors) the background is
>> >> >displayed
>> >> >>>>>> transparent. Only in mapbender pdf-print the background is
>> >> >>>>>displayed in
>> >> >>>>>> black. So I think, the solution could be in pdf-print ?
>> >> >>>>>> Has anybody observed similar problems ?
>> >> >>>>>> Has anybody a tipp ?
>> >> >>>>>> Thanks a lot
>> >> >>>>>> Herbert Schönhammer
>> >> >>>>>> _______________________________________________
>> >> >>>>>> Mapbender_users mailing list
>> >> >>>>>> Mapbender_users at lists.osgeo.org
>> >> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> >> >>>>>Michael Schulz
>> >> >>>>>mschulz at webgis.de
>> >> >>>>>in medias res
>> >> >>>>>Gesellschaft für Informationstechnologie mbH
>> >> >>>>>In den Weihermatten 66
>> >> >>>>>79108 Freiburg
>> >> >>>>>Tel +49 (0)761 556959-5
>> >> >>>>>Fax +49 (0)761 556959-6
>> >> >>>>>http://www.webgis.de / http://www.zopecms.de
>> >> >>>>>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>> >> >>>>>Eingetragen im Handelsregister HRB 5930 beim
>> >Amtsgericht Freiburg
>> >> >>>Michael Schulz
>> >> >>>in medias res
>> >> >>>79108 Freiburg
>> >> >Michael Schulz
>> >> >in medias res
>> >> >79108 Freiburg
>> >> >Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>> >Im Auftrag
>> >Armin Retterath
>> >Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
>> >beim
>> >Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
>> >Ferdinand-Sauerbruch-Straße 15
>> >56073 Koblenz
>> >Telefon 0261/492-466
>> >Telefax 0261/492-492
>> >armin.retterath at lvermgeo.rlp.de
>> >http://www.geoportal.rlp.de
>Im Auftrag
>Armin Retterath
>beim
>56073 Koblenz
More information about the Mapbender_users
