[Mapbender-users] Assign a shortcut icon to a gui
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Aug 28 04:39:29 EDT 2009
Thanks for your implementation. We should integrate this into trunk
rightaway. See my comments inline.
Thomas Baschetti schrieb:
> Hi,
> Frank Jäger schrieb:
>> is ist possible to configure a mapbender-gui with a favicon-link?
>> <head>
>> <link rel="shortcut icon" type="image/png" href="img/favicon.png">
> quick hack, assign a favicon as an element_var to element body:
> INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
> var_value, context, var_type) VALUES('gui', 'body', 'favicon',
> '../img/favicon.png', 'ein icon' ,'image/png');
I suggest we change the var_type to 'php_var'.
> and in frames/index.php right after
> right after the line
> <title><?php echo $gui_id;?> - presented by Mapbender</title>
> insert :
> <?php
> $sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND
> fkey_gui_id = $1 and var_type='image/png'";
I suggest we change the WHERE clause to read var_name = 'favicon'
instead of var_type = 'image/png'
> $v = array($gui_id);
> $t = array('s');
> $res = db_prep_query($sql,$v,$t);
> $cnt = 0;
> while($row = db_fetch_array($res)){
> echo "<link rel=\"shortcut icon\" type=\"image/png\"
> href=\"".$row["var_value"]."\">\n";
> not the nicest solution but should work.
We should commit this into trunk and add a short note at the element var
description in the wiki
http://www.mapbender.org/Body
and maybe add an enhancement ticket so we have it in the changelog.
If you don't find the time, Thomas, please let me know and I will attend
to it.
Thanks for your contribution
Christoph
> Ciao
> Thomas
INTERGEO 2009
22.-24. September 2009 in Karlsruhe
Halle 1, Stand 1.417
www.intergeo.de
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
