[Mapbender-users] problems in loading a mapserver-WMS to
mapbender
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Mon Feb 16 15:01:42 EST 2009
Hello Albert,
please change the WMS_ONLINERESOURCE in your mapfile. Always use / .
WMS_ONLINERESOURCE
"http://www.xxx.info/cgi-bin/mapserv?map=D:/ms4w/Apache/htdocs/maps/bplan.map"
Please check first whether you get an xml as response from the MapServer:
http://www.xxx.info/cgi-bin/mapserv?map=D:/ms4w/Apache/htdocs/maps/bplan.map&service=WMS&request=GetCapabilities
Then you can load the WMS in Mapbender
Best regards Astrid
On Mon, February 16, 2009 6:20 pm, Albrecht GMX wrote:
> Hi mapbender list,
> i'm just a newbie in using mapbender (but sooner or later it had to
> come ;o)
> I was just trying to load a WMS into my newly created gui. With
> geoserver-WMS it was no problem. But when loading my UMN mapserver-WMS,
> i've got an error from mapserver. Here's the error: "
> msLoadMap(): Unable to access file.
> (D:ms4wApachehtdocsmapsplan.map) ". As you might see,
> mapbender removed all backslashes of the URL. Formerly the URL
> was
> href="http://www.xxx.info/cgi-bin/mapserv?map=D:\ms4w\Apache\htdocs\maps\bplan.map&service=WMS&request=GetCapabilities">http://www.xxx.info/cgi-bin/mapserv?map=D:\ms4w\Apache\htdocs\maps\bplan.map&service=WMS&request=GetCapabilities</a> (i
> don't know, if the messages are posted somewhere on the www, so i aliased
> the url - if someone want to know, i can send the url personally via
> email). Uploading the URL in the <a class=rvts10
> href="http://localhost/mapbender/frames/index.php?&gui_id=admin_de_services">admin_de_services</a><span
> class=rvts8> was successful. Mapbender showed the capabilities found.
> Only later, when testing to show the map in the gui, i received the error.
> Does somebody know, what's wrong here?
> <span class=rvts8>Thanks at all
> Albrecht
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
More information about the Mapbender_users
