[Mapbender-users] PHP-Code in getFeatureinfo-Template
Kai Behncke
Kai-Behncke at gmx.de
Mon Jan 5 08:24:18 EST 2009
Dear list,
I`ve got a generell question to the (mapbender)-html-getFeatureinfo-Template.
If the template after a getFeatureinfo-Mouseclick pops out obviously no php-Code is parsed.
I tried it on the server-side with
"AddType application/x-httpd-php .htm .html" but also this did not work.
I wonder which possibilites exist to start php-Code after requesting the template?
So far I did it via ajax in the template with:
<body onload=javascript:php_aktivieren()>
<span id="inhalt"></span>
</body>
...and the function is:
"var resObjekt;
if (navigator.appName.search("Microsoft") > -1) {
//resObjekt = new ActiveXObject("Microsoft.XMLHTTP");
resObjekt = new ActiveXObject("MSXML2.XMLHTTP");
else {
resObjekt= new XMLHttpRequest();}
function php_aktivieren(){
resObjekt.open('get','http://localhost/gastronomap/index.php?id_datei_01=1&id_datei_02=&kategorie=grunddaten&objekt_id=[objekt_id]&gendre=[gendre]',true);
resObjekt.onreadystatechange = handleResponse;
resObjekt.send(null);
function handleResponse(){
if (resObjekt.readyState == 4){
document.getElementById("hs").innerHTML= resObjekt.responseText;
......but it seems a bit to circumstantial.
Does anybody has another solution how to integrate php-Code after a getFeatureinfo??
Thank you very much, Kai
Sensationsangebot verlängert: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K1308T4569a
More information about the Mapbender_users
