[Mapbender-users] Unable to login (function.pg-connect)
Thomas Baschetti Thomas.Baschetti at gmx.de
Thu Jan 8 11:31:23 EST 2009
>     define("DBSERVER", "127.0.0.1");
>     define("PORT", "5432");
>     define("DB", "mapbender");
>     define("OWNER", "postgres");
>     define("PW", "postgres");
these look ok, perhaps you shouldn't use the PostgreSQL admin-account for this.
Do you really use user "postgres"?
>     define("MD5","true");
>     include_once("/var/www/mapbender_2.5/http/php/database-pgsql.php");
where do these lines come from?
> And here the ERROR message from log-file:
> 2009.01.08, 16:52:45,ERROR: Error while executing prepared statement in
> /var/www/mapbender_2.5/http/frames/login.php: Sql: SELECT mb_user_login_count
> FROM mb_user WHERE mb_user_name = $1, Error: FEHLER:  keine Berechtigung
> für Relation mb_user (...no authorization)
can you connect from commandline?
Try something like
  psql -U postgres -d mapbender
and then
  select * from mb_user;
Does this work? If not your permissions in the database are not correctly set.
Ciao
Thomas
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
More information about the Mapbender_users mailing list
