[Mapbender-users] SOLVED: Mapbender 2.5 and
digitizing: featureTypeArray is not defined, map.php (line 2702)
Christoph Baudson
christoph.baudson at wheregroup.com
Thu Jan 15 06:09:28 EST 2009
Another user had the same problem, and I was able to take a look at this
installation. The cause of the problem is quite absurd.
In wfs.js, someone used an HTML comment (<!--) instead of a JavaScript
comment (//). In the SVN version, this does not cause any problems,
because the JavaScript files are uncompressed. In the release version
however, the JS files are compressed, and so the line after the comment
got corrupted by the HTML comment. Weird, isn't it?
Anyway. If you have a Mapbender 2.5 installation, replace wfs.js by the
SVN version at
http://trac.osgeo.org/mapbender/browser/tags/2.5/http/javascripts/wfs.js?format=raw
or (better, and) delete the comment in function get_wfs_str at line 341.
This should solve this problem. I have added a Trac ticket for this
problem at
http://trac.osgeo.org/mapbender/ticket/373
Thanks
Christoph
Christoph Baudson schrieb:
> Thanks for contacting us about this error.
> I cannot reproduce this in my local environment.
> Are you sure the WFS have been assigned to the application correctly?
> Maybe you updated Mapbender from an old version and sth went wrong. Go
> to application "admin_en_services", click "Assign WFS conf to GUI",
> and select the WFS from the WFS list and the application from the GUI
> list. below the GUI list you should then see a list of all available
> WFS in this application.
> If you don't see the MyPoints featuretype in there, add it from the
> right list. Otherwise, you need to debug it using Firebug. Try setting
> a breakpoint in line
> var featureTypeArray = myconf['featuretype_name'].split(':')
> and monitor the value of myconf.
> In order to do this, you need to load the Mapbender application
> "gui_digitize", then open Firebug, change to the "Script" tab, then
> select "map.php" from them selector above. Then seach for
> "featureTypeArray" in the box on the right hand side. Once you have
> found the line mentioned above, please click on the left of the line
> and mark it with a red dot (= the breakpoint). Then digitize the point
> and try to save it. The script will stop at the breakpoint. You can
> now monitor the values of all variables in the box on the lower right.
> You might also want to check http/php/mod_wfs.php, where myconf is
> defined. Check line 131. Maybe add this line
> new mb_notice("featuretype name:" . $row["featuretype_name"]);
> below line 131.
> If this doesn't help, maybe send me a link to your application.
> btw, usage of the Mapbender issue tracker at
> is generally a good idea when experiencing a bug. The developer list
> is informed instantly after you reported the issue. In order to use
> the bug tracker, please register here
> http://www.mapbender.org/Trac#Register
> Thanks, talk to you soon
> Christoph
> vollbotz schrieb:
>> hi list,
>> i have the same problem with the digitizing modul...
>> (i use the same infrastructure like matti silvennoinen )
>> after digitizing - and selecting the wfs > i could not save
>> - i got no mapbender error message / i got no ok message...
>>> in the mapbender_error_log i got the entries:
>> Notice: gui id not set
>> Notice: mb_validateSession.php: gui_id not set in script
>> mapbender/php/mod_tab_messages.php
>> Notice: mb_validateSession.php: e_id not set in script
>> and - in the firefox error-console it got the same like Matti !!!
>> featureTypeArray is not defined ...
>> but on line (line 2879)
>> hmm - the map.php has got only 145 lines....
>> does anyone know what i (we) have to do ??
>> thanks !
>> Matti Silvennoinen wrote:
>>> Hi All,
>>> I am trying to digitize objects (points and polygons) with MapBender
>>> 2.5 through Geoserver 1.5.2 (WFS-T) to postgis database but I am
>>> getting this error when completed attribute form and clicked SAVE
>>> button:
>>> Firefox 2.0.0.17:
>>> var featureNS=featureTypeArray[0];var str='<wfs:Transaction
>>> version="1.0.0" serv...
>>> map.php (line 2702)
>>> I got digitizing working with version 2.4.4 but now I try to use
>>> version 2.5. Even the example gui_digitize don't work (same error
>>> when trying to digitize "MyPoints"). The same example in version
>>> 2.4.4 works well. Do you get the same error with MB2.5 gui_digitize
>>> example and what is the solution?
>>> Regards,
>>> Matti Silvennoinen
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
