[Mapbender-users] what is needed to get mapbender 2.5 make use of new po translation files
Christoph Baudson christoph.baudson at wheregroup.com
Wed Jan 28 05:03:17 EST 2009
Hi Peter,
did you check the Mapbender log file? Maybe set your log level to
"notice" to find out what went wrong.
Did you install the locales? Check via
    locale -a
You might also have to add code to the function setSystemLocales() in
class_locale.php, in order to link the locale to the system locale.
Maybe also restart your web server, if the above is fine. I experienced
caching issues after editing and compiling po-files.
Christoph
Peter Freimuth schrieb:
> Hi list,
> we are still trying to get the translation stuff running. We added all translations to to translations table and this works fine. We have also created the new po files based with all translations for the current modules. But somehow, these new po files (allready compiled into mo format by msgfmt resources/locale/pt_PT/LC_MESSAGES/Mapbender.po -o resources/locale/pt_PT/LC_MESSAGES/Mapbender.mo ) is not used at all. We added the new language to class_language
>          * set the known languages
>         function setKnownLanguages() {
>                 $this->knownLanguages = array('en_US' => 'en_US',
>                       'en' => 'en_US',
>                       'de_DE' => 'de_DE',
>                       'de' => 'de_DE',
>                       'bg_BG' => 'bg_BG',
>                       'bg' => 'bg_BG',
>                       'es_ES' => 'es_ES',
>                       'es' => 'es_ES',
>                       'pt_PT' => 'pt_PT',
>                       'pt' => 'pt_PT',
>                       'nl_NL' => 'nl_NL',
>                       'nl' => 'nl_NL',
> 		      'fr_FR' => 'fr_FR',
>                       'fr' => 'fr_FR',
>                       'gr_GR' => 'gr_GR',
>                       'gr' => 'gr_GR',
>                       'it_IT' => 'it_IT',
>                       'it' => 'it_IT');
>  but somehow nothing happens with the digitize and spatial select button tooltips when language is change in the interface.
> Any ideas?
> Peter
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
