[Mapbender-users] .TIF files as a basemap?
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Jan 30 02:38:49 EST 2009
MeLv1n wAuRaN schrieb:
> Ok so here's the deal, i recently installed a mapbender. But i'm not
> sure whether i configured it correctly or not. so, how do i check if
> it's correctly installed/configured or not?
There is a setup checking routine in
tools/mapbender_setup.php
See
http://www.mapbender.org/Installation_en#After_the_installation_-_first_Login
> --- On *Thu, 1/29/09, "Jäger, Frank (KRZ)" /<F.Jaeger at KRZ.DE>/* wrote:
> From: "Jäger, Frank (KRZ)" <F.Jaeger at KRZ.DE>
> Subject: RE: [Mapbender-users] .TIF files as a basemap?
> To: "Mapbender User List" <mapbender_users at lists.osgeo.org>
> Cc: "MeLv1n wAuRaN" <death_knight0911 at yahoo.com>
> Date: Thursday, January 29, 2009, 11:03 PM
> Hi Milan
> From: MeLv1n wAuRaN [mailto:death_knight0911 at yahoo.com]
> Sent: Thursday, January 29, 2009 2:01 PM
> > .. i already have a mapserver 4 windows...so, do i still need to have a
> geoserver?
> Both will be able to supply a WebMapService.
> Use your mapserver for WMS
> ... until you need a transactional Web Feature Service (WFS-T) which is not
> supported by mapserver.
> You will need WFS-T only for edit vectordata (write-access) via
> Mapbender-Client, but not for your TIFs and not for any other read-access.
> >From what i read, mapserver is faster for shapefile ....
> Please ask this on mapserver-userlist.
> This list intend to discuss absout Mapbender-Client only.
> (Also your TIF-question is more a mapserver- but not a mapbender-problem.)
> > the 50 tif-files ... forms a whole map. so i think they are sorted as
> tiles
> So you can put a gdaltindex on top.
> Then insert this index into the mapfile instead of 50 single Tif-Files.
> Frank
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
