[Mapbender-users] digitize save dialog
Peter Freimuth
freimuth at rapideye.de
Fri Jan 30 07:10:37 EST 2009
Hi list,
what to do if i want defaults to be used in the save dialog for new digitized objects taken out of the current session! I have some attributes in my session which are set during login. When a new polygon is digitized and saved, the input and select elements should use the values from the session by default!
Is it possible to make the input elemts readonly or disabled?
Kind regards,
Peter
_______________________________________________________________________
Peter Freimuth phone: +49 3381 8904327
Product Development fax: +49 3381 8904101
RapidEye AG email: freimuth at rapideye.de
Molkenmarkt 30
14776 Brandenburg an der Havel http://www.rapideye.de
Germany
PRIVILEGE AND CONFIDENTIALITY NOTICE:
The information in this email is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
RapidEye AG
Molkenmarkt 30
Germany
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
DIN EN ISO 9001 certified
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
More information about the Mapbender_users
