[Mapbender-users] Re: Mapbender recognizes wrong SRS of my geoserver-WMS
Albrecht GMX aweiser at gmx.de
Mon Mar 2 05:50:29 EST 2009
Hello Astrid,
all works fine after installing postgis directly in the mapbender database. I didn't know, that this is necessary. I thought mapbender uses the postgis directly from the postgis_template. Would be an option, that the mapbender database installation sql make use of an existent postgis-database as template? Then it wouldn't be necessary to reinstall it.
But now i can use my geoserver-WMS with the other services. I think now it reprojects the maps coming from the service. Strange thing - I was again combing through the capabilities of the service, but epsg:4326 is nowhere to find. Everywhere only 31467.
Anyway - it works!
Thanks & bye
Albrecht
> Hello Albert,
> you need postgis in your Mapbender database.
> Please go to your Mapbender database and have a look whether you have
> the tables geometry_column and spatial_ref_sys.
> You also can check by the following sql :
> select postgis_full_version(); in you Mapbender database.
> If postgis is not install you can add it by three commands. Have a
> look at the postgis documentation.
> Have a look at the link see 7. to 9.:
> http://www.postgis.org/documentation/manual-1.3/ch02.html#PGInstall
> Best regards Astrid
More information about the Mapbender_users mailing list
