AW: AW: [Mapbender-users] Mapbender 2.5 - Internationalization -"Locale could not be set. Language ID: 'de'"
Manns, Marc manns at str.de
Tue May 5 08:21:35 EDT 2009
i've done some test's on a Windows server.
Even if you haven't compiled the .po file to .mo
The tooltips or tab elements should be translated to german.
Did you filled the "translations" databasetable correctly?
regards Marc
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org
[mailto:mapbender_users-bounces at lists.osgeo.org]Im Auftrag von
david.mueller at kaiserslautern.de
Gesendet: Dienstag, 5. Mai 2009 13:41
An: Mapbender User List
Betreff: Re: AW: [Mapbender-users] Mapbender 2.5 - Internationalization
i just checked my php installation and gettext support is enabled.
the errors in the logfile still appear.
do you have any other suggestion how my problem could be solved?
Is there anybody using the I118N translation on a windows server system?
thanks for your help!
Mit freundlichem Gruß
i.A. David Müller
Stadtverwaltung Kaiserslautern
Referat Stadtentwicklung
Stabsstelle Graphische Datenverarbeitung
Willy-Brandt-Platz 1
67653 Kaiserslautern
Tel  0631 - 3654043
E-Mail: david.mueller at kaiserslautern.de
Internet:  www.kaiserslautern.de
Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
http://www.kaiserslautern.de/aktuelles
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
