Antw: [Mapbender-users] Mapbender 2.5 -
Gui-Element: "setBackground"
Astrid Emde
astrid.emde at wheregroup.com
Fri May 8 09:36:17 EDT 2009
normally the setBackgroud does not make trouble.
What mapbender Version do you use?
Is your GUI available?
I tried it with Mapbender 2.6 and it still works in gui. Have a look at
your Mapbender in gui "gui". Does the Modul work in this gui? What does
firebug say.
best regards astrid
david.mueller at kaiserslautern.de schrieb:
> hi,
> yes it's marked as 'select default'.
> it's working, if i set one wms to 'hidden'.
> how do i have to configure the wms's, if i want to use more than one wms in
> de the "setBackground" modul?
> When i configure two ore more wms to 'hidden' the names are shown in the
> selectlist, but there's no map loading, when i select another wms than the
> default one.
> must there something be configured in the .map files, too?
> thanks for your help
> mapbender_users-bounces at lists.osgeo.org schrieb am 08.05.2009 09:56:17:
>> did you mark the wms as 'select default' in gui settings ?
>> Ronald
>>>>> david.mueller at kaiserslautern.de 08.05.2009 09:16 >>>
>> Hello List,
>> i've got a problem with the GUI-Element "setBackground".
>> I've made the following steps as mentioned in the mapbender wiki.
>> - set the "setBackground" ON/OFF to 1 in my GUI
>> - set my wms in the "wms gui settings" to "hidden"
>> results in:
>> - in the gui the selectbox is shown and filled with my "hidden"- WMS.
>> - but there's no reaction, when i select the wms, the mapframe stays
> white.
>> - if i set a second wms to "hidden", it also appears in the selectbox,
> but
>> there's no reaction in the mapframe, when i switch wms.
>> Has there to be any other parameter to be mentioned or edited?
>> Is there somebody, who has successfully integrated this module?
>> thanks!
>> Mit freundlichem Gruß
>> i.A. David Müller
>> Stadtverwaltung Kaiserslautern
>> Referat Stadtentwicklung
>> Stabsstelle Graphische Datenverarbeitung
>> Willy-Brandt-Platz 1
>> 67653 Kaiserslautern
>> E-Mail: david.mueller at kaiserslautern.de
>> Internet: www.kaiserslautern.de
>> Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
>> http://www.kaiserslautern.de/aktuelles
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Kompaktseminar zum Thema:
ETRS 89 - Das neue Bezugssystem
19. Mai in Bonn
http://www.wheregroup.com/etrs89_das_neue_bezugssystem
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
