Antw: AW: [Mapbender-users] MB 2.6 - html Code in digitize
	frontend
    Ronald Woita
    Ronald.Woita at rostock.de
    Wed May 13 06:16:27 EDT 2009
hi Marc
I just saw your changes this morning and it works well.
thanks
Ronald
>>> manns at str.de 13.05.2009 09:58 >>>
Hi Ronald,
Please have another look at the ticket.
I've taken some changes to SVN.
You could test, if it works for you now.
regards marc
i've seen in trac , that this  feature actually  doesn't work.
See ticket
http://trac.osgeo.org/mapbender/ticket/465
Greetings Marc
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Ronald Woita
Gesendet: Dienstag, 12. Mai 2009 12:14
An: mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] MB 2.6 - html Code in digitize frontend
hi`all,
using a simple html snippet like an option list in wfs conf doesn't work for MB 2.6 (latest version from SVN) example :
<select id="STATUS">
<option>...</option>
<option value="iv">Vertrag in Vorbereitung</option> <option value="vd">Vertrag vordigitalisiert</option> <option value="vg">Vertrag abgeschlossen</option> </select>
For earlier MB versions it works fine, but in 2.6 the option list is not displayed.
Are there any required changes for the html code syntax ?
best regards
Ronald
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
