[Mapbender-users] Displaying the area of an digitized polygon
Christoph Baudson christoph.baudson at wheregroup.com
Mon May 18 11:34:31 EDT 2009
Leukert, Boris schrieb:
> Dear all,
> I am searching for the possibility to display the area of a digitized
> polygon direct
> after closing or changing (for example moving a basepoint) it. Has
> anyone an idea?
Hi Boris,
currently we have no function to highlight an area.
However, you could highlight the border (just like the mouseover effect)
in the geometry list. You would have to create a new Mapbender event.
this event needs to be triggered when the polygon is closed. With this
event you could register an anonymous function that highlights the geometry.
If this is sufficient, we could work out the details onlist.
Cheers
Christoph
> Best regards, Boris
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Kompaktseminar zum Thema:
ETRS 89 - Das neue Bezugssystem
19. Mai in Bonn
www.wheregroup.com/de/node/547
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
