AW: [Mapbender-users] Displaying the area of an digitized polygon
Christoph Baudson christoph.baudson at wheregroup.com
Wed May 20 06:05:49 EDT 2009
Leukert, Boris schrieb:
> Hi Christoph,
> sorry for the bad description. Instead of highlighting an area I want do display
> a window (maybe an alert window) with the alphanumeric value of the area after
> closing or changing the polygon.
Hi Boris,
thanks for explaining again!
Which Mapbender version did you have in mind? I could give you basic
instructions depending on the Mapbender version you are working on. I
would suggest PostGIS for the area calculation though.
Christoph
> Best regards, Boris
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Christoph Baudson
> Gesendet: Montag, 18. Mai 2009 17:35
> An: Mapbender User List
> Betreff: Re: [Mapbender-users] Displaying the area of an digitized polygon
>> Dear all,
>> I am searching for the possibility to display the area of a digitized
>> polygon direct
>> after closing or changing (for example moving a basepoint) it. Has
>> anyone an idea?
> Hi Boris,
> currently we have no function to highlight an area.
> However, you could highlight the border (just like the mouseover effect)
> in the geometry list. You would have to create a new Mapbender event.
> this event needs to be triggered when the polygon is closed. With this
> event you could register an anonymous function that highlights the geometry.
> If this is sufficient, we could work out the details onlist.
> Cheers
> Christoph
>> Best regards, Boris
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
