[Mapbender-users] Select EPSG
Sven Böhme boehme at supportgis.de
Thu Oct 1 04:54:11 EDT 2009
Hi Frank,
thank you for your answer. But I try to change the EPSG in the
administartion GUI (WMS GUI Einstellungen /serttings). There you can
choose the EPSG  for the WMS on top. And there are only the initial EPSG
codes. But I try to use e.g. Germany WMS as background WMS and another
WMS (EPSG:31468). But I can´t change the EPSG of the Germany WMS and the
other WMS doesn´t support 4326 or 31467.
Sven
Jäger schrieb:
>> -----Original Message-----
>> From: mapbender_users-bounces at lists.osgeo.org
>> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of
>> Sven Böhme
>> Sent: Thursday, October 01, 2009 9:28 AM
>> To: Mapbender User List
>> Subject: [Mapbender-users] Select EPSG
>> Hi,
>> in the WMS GUI settings I can choose the EPSG. But I can only
>> chosse between two EPSG code, although the WMS supports more
>> than two codes.
>> How can I use e.g. EPSG:31468 for Germany WMS?
>> Thanks
>> Sven
> Hi,
> /php/mod_changeEPSG.php doesn't look at the WMS.
> Available EPSG-Codes are hard coded. I changed it to my needs:
> <form action="<?php echo $self;  ?>" method='POST'>
> <select class='epsg' name='epsg' onchange='mod_changeEPSG()'>
> <option value="">undefined</option>
> <option value="EPSG:31467">Gau&szlig;-Kr&uuml;ger 3 (31467)</option>
> <option value="EPSG:25832">ETRS89/UTM (25832)</option>
> <!-- <option value="EPSG:4326">Geogr. Koord.(4326)</option> -->
> </select>
> "EPSG:4326" doesn't work with minscale/maxscale and "setScaleHint" in a GUI.
> Frank
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Dipl.-Geogr. Sven Böhme
CPA Systems GmbH
Grantham-Allee 2-8
D-53757 Sankt Augustin
Tel.: +49 (0) 2241 / 25 94 -- 24
Fax.: +49 (0) 2241 / 25 94 - 29
www.cpa-systems.de
Handelsregister:
HRB 9706, Amtsgericht Siegburg
Geschäftsführer:
Dr.-Ing. habil. Christoph Averdung
Dr.-Ing. René Thiele
Dr.-Ing. Matthias Ellsiepen
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20091001/3e019a43/attachment-0001.html
More information about the Mapbender_users mailing list
