[Mapbender-users] Create points with a geoserver WFS-T
Daniel Grum
daniel.grum at unibw.de
Thu Oct 15 05:26:42 EDT 2009
Sebastian Krohn-Grimberghe schrieb:
> Hello Daniel,
>> If I unstand you correctly, I have to write a function in my PostgreSQL
>> database. I never programmed a function in PostgreSQL by my
>> self...should this be sth. like a Trigger: so the Trigger startet after
>> the user created the object?! and wrote the message? and stop the
>> action
>> saving the new point in my database!
> You are right... You can create a trigger for your geometry table, which is
> called when GeoServer inserts a new geometry into the table. There you can
> check with PostGIS functions if the new (buffered) point intersects other
> geometries. If the point intersects another geometry you can raise an
> exception. By raising the exception the new point will not be stored in the
> database and GeoServer should receive and pass a failure message.
> The trigger function could look like this:
> CREATE OR REPLACE FUNCTION my_trigger_function() RETURNS trigger AS
> DECLARE
> -- declare variables
> current_row RECORD;
> BEGIN
> -- get all existing geometries which intersect the new geometry
> (NEW.the_geom)
> -- around the new geometry is a buffer of 50 meters (or whatever
> your unit is)
> FOR current_row IN SELECT * from my_geom_table t WHERE
> ST_Intersects(ST_Buffer(NEW.the_geom, 50),t.the_geom) LOOP
> -- intersection found
> RAISE EXCEPTION 'my error message';
> END LOOP;
> -- no intersection, new geometry will be inserted
> RETURN NEW;
> END;
> $$ LANGUAGE 'plpgsql';
> CREATE TRIGGER my_trigger BEFORE INSERT OR UPDATE ON my_geom_table FOR EACH
> ROW EXECUTE PROCEDURE my_trigger_function();
> I use a similar trigger with an OpenLayers client. When an exception is
> raised, GeoServer returns XML with a failure information. But the message is
> always the same, so it is not affected by the error message in the trigger
> function. I do not know how the error messages of WFS transactions are
> handled by Mapbender. So I cannot help you with this yet, but I hope this
> helps you with the database part.
> Best regards,
> Sebastian
> Entwicklung
> IP SYSCON GmbH
> Tiestestraße 16-18
> D-30171 Hannover
> Tel.: +49 (511) 85 03 03 - 0
> Fax: +49 (511) 85 03 03 - 30
> E-Mail: sebastian.krohn-grimberghe at ipsyscon.de
> http://www.ipsyscon.de/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
I tried to solve the problem, but after I made this TRIGGER function I
can not create new points(buildings) anymore!!! I allways get the
message that the new point can not by saved in my database from the
WFS-T :-(
My TRIGGER function is:
-- Function: my_trigger_function()
-- DROP FUNCTION my_trigger_function();
RETURNS trigger AS
$BODY$
DECLARE
current_row RECORD;
BEGIN
NEW.the_geom
your unit is)
FOR current_row IN
SELECT *
FROM public.holzfaeller t, public.erzmine e, public.wohnhaus w,
public.steinbruch s, public.kaserne k, public.saegerwerk r
WHERE ST_Intersects(ST_Buffer(NEW.the_geom, 5),t.the_geom) AND
ST_Intersects(ST_Buffer(NEW.the_geom, 5),e.the_geom) AND
ST_Intersects(ST_Buffer(NEW.the_geom, 5),w.the_geom) AND
ST_Intersects(ST_Buffer(NEW.the_geom, 5),s.the_geom) AND
ST_Intersects(ST_Buffer(NEW.the_geom, 5),k.the_geom) AND
ST_Intersects(ST_Buffer(NEW.the_geom, 5),r.the_geom)
LOOP
RAISE EXCEPTION 'Gebaeude kann hier nicht errichtet werden!!!';
END LOOP;
RETURN NEW;
END;
$BODY$
LANGUAGE 'plpgsql' VOLATILE
COST 100;
ALTER FUNCTION my_trigger_function() OWNER TO postgres;
I tried a low buffer but the but the error message was the same :-(
Where can be the mistake???
--daniel
More information about the Mapbender_users
