[Mapbender-users] Create points with a geoserver WFS-T
Sebastian Krohn-Grimberghe
sebastian.krohn-grimberghe at ipsyscon.de
Thu Oct 15 07:17:49 EDT 2009
Hello,
> FOR current_row IN
> SELECT *
> FROM public.holzfaeller t, public.erzmine e, public.wohnhaus w,
> public.steinbruch s, public.kaserne k, public.saegerwerk r
> WHERE ST_Intersects(ST_Buffer(NEW.the_geom, 5),t.the_geom)
> AND
> ST_Intersects(ST_Buffer(NEW.the_geom, 5),e.the_geom) AND
> ST_Intersects(ST_Buffer(NEW.the_geom, 5),w.the_geom) AND
> ST_Intersects(ST_Buffer(NEW.the_geom, 5),s.the_geom) AND
> ST_Intersects(ST_Buffer(NEW.the_geom, 5),k.the_geom) AND
> ST_Intersects(ST_Buffer(NEW.the_geom, 5),r.the_geom)
> LOOP
> -- intersection found
> RAISE EXCEPTION 'Gebaeude kann hier nicht errichtet werden!!!';
> END LOOP;
> -- no intersection, new geometry will be inserted
> RETURN NEW;
I guess the mistake is in the SELECT statement. First of all you should
replace each AND by OR. Because with AND a new geometry is only not
inserted if it intersects a geometry in each table. But I guess you do not
want to insert a new geometry even if it intersects a geometry in only one
table.
But this should not be the only mistake. So you could check the SELECT
statement on its own. Replace NEW.the_geom by a geometry like
GeomFromText('POINT(1 1)',-1) WHERE -1 must be replaced by your EPGS
code and check if the statement returns what you are expecting.
Or you could change the trigger function by making a LOOP for each table,
like:
FOR current_row IN
SELECT * FROM public.holzfaeller t
LOOP
END LOOP;
FOR current_row IN
SELECT * FROM public.erzmine e
WHERE ST_Intersects(ST_Buffer(NEW.the_geom, 5),e.the_geom)
LOOP
END LOOP;
more LOOPs
RETURN NEW;
Best regards,
Sebastian
Entwicklung
IP SYSCON GmbH
Tiestestraße 16-18
D-30171 Hannover
More information about the Mapbender_users
