[Mapbender-users] Problems with my initial view (BBOX)
Lluís Vicens
lluis at sigte.udg.es
Thu Oct 22 04:37:15 EDT 2009
Hi Michael,
A lot of thanks for your answer. The setBBOX module is definitely
enabled in my gui as you can see in the attached image, but it doesn't
works. I'm working with mapbender_2.6_rc1. But looking at
http://www.mapbender.org/Mb_mybbox I can see that my mod_setBBOX1.php is
different from the one you can download from:
http://trac.osgeo.org/mapbender/browser/trunk/mapbender/http/javascripts/mod_setBBOX1.php?format=raw
How should I proceed? Which is the problem? Which mod_setBBOX1.php I
have to use: the script that originally comes from 2.6_rc1 (15 lines of
code) or the one that can be downloaded from the link posted above (97
lines of code). The difference between them is notable.
¿Any advise?
Thanks in advance!
Lluís
En/na Michael Schulz ha escrit:
> Hi Lluís,
> you need to have the module setBBOX enabled for the GUI you want to
> set a start extent with mb_myBBOX. Have you checked that this module
> is present an enabled in your GUI? See here:
> If it still not working, please give us teh Mapbender Version you're
> working with. I think to recall there was a MB 2.5 Version that had a
> typo in ./conf/session.conf wrt. to the mb_myBBOX parameter, but I am
> not sure...
> HTH, michael
> 2009/10/21 Lluís Vicens <lluis at sigte.udg.es>:
>> Hi,
>> I have a little problem (well, in fact this is one of my problems!) that I
>> tried to solve for myself reading the wiki (mapbender documentation) as well
>> as some of the mailing list archives but I cannot find a solution. How can I
>> define my initial extent with mapbender? I tried several options regarding
>> to the BBOX even I put manually the parameter &mb_myBBOX= into the URL but
>> it doesn't work :(
>> I want to fix my initial view based on EPSG:4326 where minx,miny,maxx,maxy
>> are 2.4354,41.7065,3.1989,42.2430. My base cartography WMS is
>> "http://shagrat.icc.es:80/lizardtech/iserv/ows?" and if I check (firebug)
>> which is the request that mapbender is doing to this server the result is
>> http://shagrat.icc.cat/lizardtech/iserv/ows?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=sat250m&STYLES=&SRS=EPSG:4326
>> &BBOX=-24.5,27.14789603960396,34.5,75.85210396039604&WIDTH=808&HEIGHT=667&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE
>> &EXCEPTIONS=application/vnd.ogc.se_xml&
>> ¿How could I define my initial bbox?
>> Thanks in advance for your help and sorry if this is a question answered so
>> many times before... :-[
>> Regards,
>> Lluís
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20091022/2f1b28fd/mapbender_gui-0001.png
More information about the Mapbender_users
