[Mapbender-users] Problems with my initial view (BBOX)
Michael Schulz
mschulz at webgis.de
Tue Oct 27 06:50:53 EDT 2009
Hi Lluís,
you should definitely stick to the version that ships with your
mapbender installation. The link you mention points to the trunk aka
development version.
Are there any JavaScript errors... also have a look at the mapbender
error log file. Is the extent you're providing in the correct srs?
Hm, just read your first post again. You *have* to start Mapbender
with the mb_myBBOX parameter set, and especially you'll need to start
it with http://mydomain/login.php?name=name&password=password&mb_user_myGUI=gui&mb_myBBOX=....
You can find it here: http://www.mapbender.org/GUI_Start_Parameters
Cheers, Michael
2009/10/27 Lluís Vicens <lluis at sigte.udg.es>:
> Sorry, I forgot to say that I am working on an Ubuntu 8.04...
> Thanks!
> Lluís
> En/na Lluís Vicens ha escrit:
>> Hi Michael,
>> A lot of thanks for your answer. The setBBOX module is definitely enabled
>> in my gui as you can see in the attached image, but it doesn't works. I'm
>> working with mapbender_2.6_rc1. But looking at
>> http://www.mapbender.org/Mb_mybbox I can see that my mod_setBBOX1.php is
>> different from the one you can download from:
>> http://trac.osgeo.org/mapbender/browser/trunk/mapbender/http/javascripts/mod_setBBOX1.php?format=raw
>> How should I proceed? Which is the problem? Which mod_setBBOX1.php I have
>> to use: the script that originally comes from 2.6_rc1 (15 lines of code) or
>> the one that can be downloaded from the link posted above (97 lines of
>> code). The difference between them is notable.
>> ¿Any advise?
>> Thanks in advance!
>> Lluís
>> En/na Michael Schulz ha escrit:
>>> Hi Lluís,
>>> you need to have the module setBBOX enabled for the GUI you want to
>>> set a start extent with mb_myBBOX. Have you checked that this module
>>> is present an enabled in your GUI? See here:
>>> If it still not working, please give us teh Mapbender Version you're
>>> working with. I think to recall there was a MB 2.5 Version that had a
>>> typo in ./conf/session.conf wrt. to the mb_myBBOX parameter, but I am
>>> not sure...
>>> HTH, michael
>>> 2009/10/21 Lluís Vicens <lluis at sigte.udg.es>:
>>>> Hi,
>>>> I have a little problem (well, in fact this is one of my problems!) that
>>>> I
>>>> tried to solve for myself reading the wiki (mapbender documentation) as
>>>> well
>>>> as some of the mailing list archives but I cannot find a solution. How
>>>> can I
>>>> define my initial extent with mapbender? I tried several options
>>>> regarding
>>>> to the BBOX even I put manually the parameter &mb_myBBOX= into the URL
>>>> but
>>>> it doesn't work :(
>>>> I want to fix my initial view based on EPSG:4326 where
>>>> minx,miny,maxx,maxy
>>>> are 2.4354,41.7065,3.1989,42.2430. My base cartography WMS is
>>>> "http://shagrat.icc.es:80/lizardtech/iserv/ows?" and if I check
>>>> (firebug)
>>>> which is the request that mapbender is doing to this server the result
>>>> is
>>>> http://shagrat.icc.cat/lizardtech/iserv/ows?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=sat250m&STYLES=&SRS=EPSG:4326
>>>> &BBOX=-24.5,27.14789603960396,34.5,75.85210396039604&WIDTH=808&HEIGHT=667&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE
>>>> &EXCEPTIONS=application/vnd.ogc.se_xml&
>>>> ¿How could I define my initial bbox?
>>>> Thanks in advance for your help and sorry if this is a question answered
>>>> so
>>>> many times before... :-[
>>>> Regards,
>>>> Lluís
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
