Re: [Mapbender-users] mb print_pdf: wrong scale / mp druck: falscher Maßstab
Thomas Baschetti info at thomas-baschetti.de
Fri Sep 18 06:20:02 EDT 2009
v.botz schrieb:
> Hi,
> i use mapbender 2.5 on an ubuntu gis_vm. print in a3 and a4.
> i have the following probling with the pdf print:
> 1. the printed scale is wrong
>     (for example 100 meter in map are 95 in print)
scale should be correct.
Do you use Acrobat Reader to print? Then uncheck 'scale to fit' or
whatever it is called
in the print dialog, otherwise Acrobat Reader scales the pdf (usually
makes it smaller).
Ciao
Thomas
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
Ust-IdNr.: DE264355072
More information about the Mapbender_users mailing list
