[Mapbender-users] zoom to coordinates out of a popup window
Andreas Voit a_voit at gmx.at
Tue Apr 13 11:10:38 EDT 2010
hallo,
I already send the source code, I mean the line where the error occurs.
Again:
"$target=$_GET('target');" is the line where the error occurs. But as
attachment I send you also the source code. I marked the line with the
comment "<!-- HERE OCCURS THE ERROR -->".
In the mapbender GUI I created a button to open the formular. The
attributes in the GUI configuration: 'onclick='searchWindow =
window.open("/form/form.php?sessionID&target=mapframe1,overview","searchWin","width=800,
height=600, scrollbars=yes, resizable=yes");');'
In summary it's normal formular, I have to get some values for dropdown
list from an postgreSQL db (Bezirke). I know it is not a elegant
solution, but it works ;)
hope you can help me.
cu
Am 13.04.2010 16:21, schrieb Christoph Baudson (Wheregroup):
> Hi Andreas,
> thanks for your mail. Please forward the source of form.php and the line
> where the error occured.
> Thanks,
> Christoph
> Andreas Voit schrieb:
>> hallo,
>> I'd like to press a button in a popup window and then it should zoom to
>> a location.
>> I found the tool "zoomCoords" in GUI1. But that only works if it is used
>> in the map user interface. I want to uses it in a popup window.
>> so it has problem to find the function "zoom", I guess it is a map
>> specific function and is only available at the map gui.
>> <code>
>>     zoom(mod_zoomCoords_target[0],true, 1.0,x,y);
>> </code>
>> As you can see in the code example there is use a variable
>> "mod_zoomCoords_target[0]", which I guess is "mapframe1,overview".
>> So I tried to make a url query string to my own gui element button:
>> <code>
>> window.open("form.php?sessionID&target=mapframe1,overview","searchWin","width=800,
>> height=600, scrollbars=yes, resizable=yes");');'<?php
>> $target=$_GET('target');?>
>> </code>
>> In my form.php I want to save the value of target into a variable like:
>> <code>
>>     <?php $target=$_GET('target');?>
>> </code>
>> Then I get an error: Fatal error: "Function name must be a string in
>> \mapbender\http\form\form.php"
>> In summery I want to zoom to a location in a map, by pressing a custom
>> button, which is in a popup window.
>> Does anyone know a solution, I would be happy ;)
>> cu
>> My System
>> Mapbender 2.6
>> Windows XP + SP3
>> XAMPP 1.7.3
>> Database Postgres 8.4 + PostGIS
>> GeoServer 2.0.1
Andreas Voit
http://andreasvoit.heim.at/
Windows kam, sah und versagte
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20100413/3248fe8a/form-0001.html
More information about the Mapbender_users mailing list
