[Mapbender-users] call Mapbender-instance with WMS-URL
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Tue Apr 13 11:11:24 EDT 2010
Milad84 schrieb:
> Hi guys,
> I m new to Mapbender and have already a question. I would like to call an
> Mapbender instance with a WMS-URL as a parameter, so that the
> Mapbender-client opens with the WMS already loaded.
> is that possible?
> thanks
> Milad
It should work like this
(1) Compose your URL like this
http://mapbender.telascience.org/mapbender_trunk/frames/login.php?name=demo&password=demo&mb_user_myGui=template_basic
and append a GET parameter
&wms1=<your urlencoded capabilities url>
(2) make sure you have the element "loadWMC" in your application, check
"edit GUI elements.
(3) make sure "loadFromSession" is activated (set to 1) in "loadWMC".
Click the link "loadWMC" in "edit GUI elements" and check. If not
present, add it,
value: 1
type: php var
Please share your experience. I would like to know if it works for you.
Thanks,
Christoph
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
