[Mapbender-users] Re: call Mapbender-instance with WMS-URL
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Thu Apr 15 03:25:09 EDT 2010
Milad84 schrieb:
> hi..
> I followed all the instructions. I added the variable and i tried it with
> login.php and index.php. nor did work.
> Maybe my wms is added but I just cant see it? But I assume that the wms
> should appear in the left-hand tree aswell. Am I right?
I will look into it today and will let you know. Thanks for bringing it
to our attention.
Christoph
> Michael Schulz wrote:
>> Milad,
>> if you can't find the element var "loadFromSession" you'll have to set
>> it using the edit gui form. Tto check/set the element var click on the
>> link of the element id "loadwmc" - not the checkbox.
>> I am not 100% sure, but i think you have to use login.php not
>> index.php. Try the link again, supplying a name, password, if that
>> user has more than one gui assigned you need to supply the gui_id as
>> well (as mb_user_myGui) and then the wms1 url, like this:
>> http://localhost/mapbender26/http/frames/login.php?name=test&password=test&mb_user_myGui=gui1&
>> &wms1=http%3A%2F%2Fintergeo.sdisuite.de%3A80%2Fwmsconnector%2Fgdi%2Fbrd%3Frequest%3Dgetcapabilities%26service%3Dwms
>> HTH, Michael
>> 2010/4/14 Milad84 <milad1984 at gmail.com>:
>>> Hi,
>>> well I updated mapbender to 2.6 but it still doesnt work. I try to load
>>> my
>>> gui1 with a wms. checked the gui and the loadWMC is enabled but I still
>>> didnt find something about loadFromSession
>>> my link looks as followed..
>>> http://localhost/mapbender26/http/frames/index.php?&gui_id=gui1&wms1=http%3A%2F%2Fintergeo.sdisuite.de%3A80%2Fwmsconnector%2Fgdi%2Fbrd%3Frequest%3Dgetcapabilities%26service%3Dwms
>>> greets
>>> milad
>>> View this message in context:
>>> http://n2.nabble.com/call-Mapbender-instance-with-WMS-URL-tp4896325p4901984.html
>>> Sent from the mapbender-users mailing list archive at Nabble.com.
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Aufwind durch Wissen!
>> Qualifizierte Open Source Schulungen bei der
>> http://www.foss-academy.eu/
>> Michael Schulz
>> mschulz at webgis.de
>> in medias res
>> Gesellschaft für Informationstechnologie mbH
>> Schwimmbadstraße 2
>> D-79100 Freiburg i. Br.
>> Tel: +49 (0)761 705798-102
>> Tel: +49 (0)761 705798-0
>> Fax: +49 (0)761 705798-09
>> http://www.webgis.de / http://www.zopecms.de
>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
